the method of using steam will not work. it will simply boil dry before the oil has heated up much at all. it will heat it a little. i cant see it making any flow unless you have a condensor somewhere in the system. or it is a total loss system with a popet valve on the exit of the oil cooler with less of a relief pressure than the little header tank you intend to use.
having it plumbed into the cooling system is a no go. i wouldnt want any extra air getting into the engine. either way it would have to be refilled and bled each cold start.
it would be better to just use a coolant heat exhanger instead i think.
It would be a seperate closed coolant system circuit from the engine. Engines cooling system works just fine when its up to temp and shouldnt be messed with, as does the engines oil cooling system. Oil temps have never been higher than 85 degrees.
Im not sure you quite follow what I mean by convection pumping. Have you ever shutdown a gtr and listened to the cooling system work when the engine isnt running? Coolant flows into the turbo's, boils, and then blows out as steam to the return line to the top radiator hose outlet. Because the turbo's are below the highest point of the cooling system, gravity again causes coolant to flow into the turbo's again, and the cycle repeats.
The heat exchanger will work as a condensor while heating the oil as the goal isnt to heat the oil beyond 100 degrees. Granted the efficency of the heat exchange AS A CONDENSOR will drop off as the optimal temperature is reached.
The line from the heater coil will probably have to be a hard line so it will survive the heat long term. It may also need to be thermally insulated to keep the heat in more, but experimentation will quickly identify that. Even if the whole system gets that hot that is boiling and full of steam, it will still heat the oil and then eventually shut itself off when 80 degrees is reached. Excess pressure would be vented to a seperate overflow container the same as a radiator.
OR.. you coild use 2 110v heaters wired in series to make up for the 240 volt here..
Electric heaters are practical for race cars, but this is a street car. Having to plug the car into a power point for a 1/2 hour every time I drive it would be as annoying as idling it in the driveway is.
Hey guys I haven't got any experience with dry sumped cars but I do have experience with industrial hydraulics and think your over engineering and overlooking a simple fix. That is IF the oil filter was still in the original position on the block.
Please correct me if my understanding is wrong but is your setup like the circuit in the top sketch?
If you were to able to run 2 thermostat's you would be able to quickly heat enough oil to circulate and not damage the motor and as the motor keeps heating it would slowly start purging into the sump whilst heating that too.
A very simplistic view of it but it might just work.
Chris
I say just get one or two rather large 12V batteries, put them on a trolley and get 3 of the 12V heaters on the tank. Just use a fat cable with a big fat connector to hook the bat(s) to the heaters for the time that you need to warm it up, then take the battery trolley away and plug it into a charger while you go race.
That way you can warm it up even if you aren't in a pit where you have access to mains power.
just get an oil heater off ebay and the like, very common in the usa in sub zero climates, cheap too. Should sit tin the tank no issues.
The ones i saw were pretty much kettle elements but larger..
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
