Phillcom Rally Time Attack Round 3 2010
The Mitsubishi GSR/EVO Club Present Round 3 of the 3 part Phillcom Rally Time Attack Series 2010.
The event will be held at Mallala Motor Sport Park on Monday (Public Holiday) 4th October 2010.
The Phillcom Rally Time Attack Round 3 will be limited to ONLY 36 entries.
Competition will be based on timed hot laps with ample opportunities to attain a personal best.
Combined with Modification Classes and DOT Tyre Restrictions, the final round of the series introduces Open Practice and a NEW Top 10 Shoot-Out to deliver dynamic levels of competition!
Local Tuner Houses will again battle it out for workshop honours, with the top 3 Tuner House drivers on equal points leading into the final round!
Trophies for ALL Classes, privateers are welcome and catered for.
This event is sure to please both competitors and spectators with the best drivers and workshop machines providing non-stop action!
Competitiors must have a minimum L2S or L2SJ CAMS Licence and CAMS Car Club Membership to enter. Click here if you do not have these items.
All Tuner Houses and Businesses are welcome to compete in the Phillcom Rally Time Attack Series 2010. Please contact [email protected] for further details.
For all information on Phillcom Rally Time Attack Round 3 October 4th 2010 please view here.
Time Attack Sponsors
Phillcom Rally
Infinity Signs
Willall Racing
Lakeview Chiropractic
Adelaide Radial Tyre
S & J Automotive
Autosport
Australian Motors Mitsubishi
pdf-med.gifPhillcom Rally Time Attack Round 3 2010 ENTRY FORM
pdf-med.gifPhillcom Rally Time Attack Round 3 2010 SUPP REGS
https://www.sau.com.au/forums/topic/333803-phillcom-rally-time-attack-round-3/
  • 1 month later...
Phillcom Rally Time Attack Round 3 - PROVISIONAL RESULTS
Phillcom Rally Time Attack Round 3 Overall Winner
1st Place Top Ten Shoot-Out: PHILLCOM RALLY Steve Knight - EVO 6 01:13.196
OPEN 2WD Trophy
1st Place: LAKEVIEW CHIROPRACTIC Brad Trenwith - FD3S RX7 01:14.797
2nd Place: LAKEVIEW CHIROPRACTIC Jason Unkovich - FD3S RX7 01:15.003
CLUB 2WD Trophy
1st Place: Tim O'Daly - 911 GT3 01:19.067
2nd Place: Ryan Probert - S14 SILVIA 01:19.185
OPEN AWD Trophy
1st Place: PHILLCOM RALLY Steve Knight - EVO 6 01:13.057
2nd Place: WILLALL RACING Keir Wilson - R35 GTR 01:14.036
CLUB AWD Trophy
1st Place: WILLALL RACING Martin Donnon - EVO 10 01:16.546
2nd Place: PHILLCOM RALLY Matthew Dreckow - EVO 7RS 01:17.294
Tuner Trophy
pdf-med.gifPhillcom Rally Time Attack Round 3 PROVISIONAL RESULTS - NOW AVAILABLE!
Really spewing I missed this - had been looking forward to it all year end even checked the Phillcom website several times but for some reason only saw stuff about last years (which was awesome!). Note to self - check the events section more regularly. :D
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
