bcnr33 body shell. Complied.
Engine bay has boosters+lines + pwr steer bottles etc. Engine bay has been freshly painted black.
tailshaft still bolted in
Suspension :
nismo s tune
Hubs etc but no brakes
Rear diff and cradle
(complete cradles just no brakes)
Interior
Dash+all glass rubbers+seat belts
series 3 interior
door trims and rear 1/4 trims
passenger seat
minus drivers seat
Exterior
As seen in pics, the car has no front panels but doors back is complete.
Contact me directly on : 0422745620.
Car can be viewed anytime, i am keen to move it on as i dont have the time to finish it.
$5000 brisbane can assist with freight
Edited by fungtr
1995
Suspension :
nismo s tune
Interior
series 3 interior
passenger seat
minus drivers seat
Exterior
appologies for quality of pics..the camera was playing up..
there is also a rear bar with the car
how much for lhr wheel hub and driveshaft. only interested in the driveshaft if the bolts that locate it to the diff arent threaded. the type i need has the bigger not threaded holes. the threaded holes on the inner joint are spaced slightly closer to the inside of the joint and wont fit my diff
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
