Hey Guys,
Got an R32 four door which im tracking, so basically got full interior apart from dash and front part of the centre console.
Interior is greyish velour and in very good condition!
if you need any other parts let me know and i will let you know if i have them!
Please Call
Anthony
0411 117 167
or
P.M me
https://www.sau.com.au/forums/topic/333850-r32-four-door-interior-other-parts/
Hi,
Are you offering the passenger and driver side kick panels?
Also interested in the rear seat if it's in good condition.
PM me
hey champ i tried calling u n got no answer, im keen on all four door trims and the trims that go beside the rear window/door and same at the front
Cheers
Call or PM with a price 0450 194 170
cheers - Brad
