Hey guys,
Been a while since my last tutorial so thought it was time for another while I was fixing something.
Long story short, For the past 6 weeks now my starter motor has had a really loud squeal for the first 2 seconds of turning on the car and I was sick of it and worried something bad would eventually happen.
DISCLAIMER: This is how I fixed my squeal, yours may be more serious and need a replacement unit. I take no responsibility if someone attempts this and the results are not the same as mine. Also, none of the cog fins were bent in mine, meaning it had not been rubbing against the flywheel so I knew there was not going to be any damage putting it back in and reusing it.
Tools:
Torch - I guarantee it is necessary
A good socket set
A pair of hands that can get into VERY tight places
Lubricants and cleaning agents
Time required: 15-30mins for someone who has taken it off before, 1hr+ for someone who hasent. 15 mins of cleaning and another 30 mins of putting it back on.
Level of difficulty: Easy-Medium
1. Disconnect the battery as it is wired directly to the starter motor. For R33 that normally involves getting into the boot behind the carpet. Instead, I decided to disconnect the terminal that the starter motor connects directly to in the engine bay. It is under the fuse box lid located on the drivers side. Make sure you cover the lead so it doesn't touch anything, just to be safe
2. Find the Starter motor. It is located here
3. Remove this plastic cover on the solenoid and undo the bolt that holds the lead to it and disconnect the thin black wire as well. There should now be no wires connected to the starter motor and solenoid.
It is best to do this from the top of the car, not underneath.
4. Get underneath the car and only just loosen the bolt in the bottom left hand corner of this picture a tiny bit. This is because it is one of the two bolts that holds the starter motor to the bell housing and the other one is much harder to get to so this will take the pressure off the top one.
5. Now the top one. This one takes the most of your time. It is probably one of the hardest bolts I have ever had to get to on the Skyline. I managed to get it from on top, but whatever way works for you.
It is located just in front of the firewall towards the top of the bell housing that faces the front of the car. It took me 5 minutes just to get this clear pic.
If you are struggling, the way I did it is get onto the engine, put one knee on the drivers side strut tower, the other on the radiator support bar and looked right down here towards the ground. I then used my left arm and ripped 500 grams of skin off by jamming it all the way down there with my ratchet and a 14mm socket and took it off while watching it from the top.
6. That was the hardest part. Now undo the bottom bolt and remove the unit from the engine. I did it from underneath.
This is what you get. Very dirty.
7. Clean it up internally as best you can, I used a combo of degreaser and wd40 to clean it up. The problem with these though Is they get rid of grease and you do want some. Once it was as clean as I could get it I needed to Lube it. We had some Motul chain lube spare which is a thin grease, which is good for this application.
8. This is how it should look cleanish. You should be able to move it one way fairly easily, it will be a little stiff, the other way should be very very stiff if not movable at all. This is because it is a one way bearing.
9. Now put back in the reverse method of above. Once again I put the bottom bolt in first from undearneath, then got on top of the motor and did the top one, found it alot easier putting the unit back in then getting it out.
And your done! Hope this helped you guys.
Adam
BIG TIP: If you want to test it out of the car and see if it still squeals after being cleaned, get a car battery and hook it up to it for a few seconds. You could also hook it back into the car and hold it while it spins, just be careful.
https://www.sau.com.au/forums/topic/333872-fixing-starter-motor-squeal/
just as a side note.... pulling that terminal off in the engine bay could result in shorting to chassis. You should always disconnect the negative terminal from the battery so that you remove the 'ground' circuit and you cant have wires still shorting to the chassis
other then that good write up, hopefully I'll never have to do it but its good to know for when it happens lol
Yeh, honestly was not 100% sure but my way seemed to work if you are careful with the terminal. For me to get to my battery from the boot would take about 1.5-2 hours alone to remove amps mounted on a custom floating wall and all that, and I normally go through the back seat by removing the backseat and the plate behind it but it was raining outside and I was doing it in my garage where i can only open my door 1/3 of the way to get out so I couldn't pull out my backseat :(
glad you guys liked it.
One further thing that should be noted, the bushes in these are sintered bronze bushes, meaning they are porous. They are soaked with oil before fitting as this is the only lube they get. In the link showing the picture below, it shows quite a lot of clutch dust stuck to the housing. This dust can get into the bush and soak the oil up. Its usually worse if the driver continually slips the clutch, either by riding it or slipping it a lot during take off.
Edited by kjb_r33
  • 7 months later...
not much experience with starters screeching n shiz... but my 33gtrs one is spastic sounds like crap when u crank it and even after u let go for a split second it still does it .... since its got low comp and a bottom end knock i think ill just have a look into that now :D STARTER SKILLZ ERE I COME! lol thanks for the diy WYTSKY!
One further thing that should be noted, the bushes in these are sintered bronze bushes, meaning they are porous. They are soaked with oil before fitting as this is the only lube they get. In the link showing the picture below, it shows quite a lot of clutch dust stuck to the housing. ....
That is probably from when I turboed the car and the factory n/a clutch went in 4 hrs :P
You welcome :)
  • 6 months later...
this is a long shot but I got my starter motor in bits but i cant get this piece out..
its the last bit, im pretty sure that white ring should pop out but I cant get it to budge..
heres the rest of the bits if anyone is interested
also the only grease i have is castrol High temp wheel bearing grease and a can wd40 3in1 lubricant which is for chains and stuff but its very thin
http://www.3inone.com/products/ptfe-spray-lubricant/
thats what i thought as well but there is no way to get the fork out..
its like the whole assembly just need to slide upwards and out but i cant get it to budge..
Do you know how to get the fork out?
this is interesting, 626 starter motor is identical..to mine..
couldnt hit the end with a shaft becaue it has a cap on top..
What i did do is soak it in wd40 fro the night..still wouldnt budge..turned it upside down and shook it like crazy cause the wheel kept bouncing i guess it slowly tapped itself out till it fell on the table :D
Thing is packed with clutch dust though, i think it will appreciate the clean
  • 1 month later...
  • 7 months later...
The easiest way to get to the top bolt is to have about 2 long extentions on the ratchet and a bendy adaptor behind the socket, then push it in from the front. I managed to get it on there first go, but that might have been pot luck. I had the old one out and the new one in in under an hour.
I got mine out easy and it was on a 32 (RB25) which means less space. First unbolted the fueI line bracket and fuel filter brackets and pushed them down and forwards, used a deep socket and a short extension (about 5cm) and put my right arm down between the strut tower and under the plenum while looking down just behind the plenum with a small torch. Socket on and push downwards. May have to unplug and move the injector harness a bit, but this way did not take long at all.
  • 5 years later...
bit of a topic revival - the whining sound that comes from it - would you get it from starting up the car, then it stops, then it starts back up again?
I'm starting to get a high pitched squeal on intermittent start ups - wracking my head as to what is actually the cause, but then also after driving for a while the sound will come back and then go. it sounds like an angry bearing noise.
Edited by BstewyR33
Have you checked your belts? What you're describing sounds more like a loose belt
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
