Hey guys,
Pretty sure I need new brake pads and rotors, but Im now getting a terrible grinding sound occasionally coming from the brakes when Im turning without applying any brakes..
Had a look and you can see there is definantly strange wear on the left and right sides - the rears are fine.
Im thinking a wheel bearing might be gone, but I cant physically wobble the wheels with my hands..
Any ideas?
Passenger Front.
Drivers front
https://www.sau.com.au/forums/topic/333884-brakes-help-needed/
oh, I fuxked up all my pads and the rear rotors today at wakefield. Anyone know what pads will be good for the track?
My V35 is an automatic without brembo. Thanks for anyhelp=)
I did just the same thing @ QR about 2 weeks ago except I managed to crack my RDA slotted discs at the front as well
Just replaced with DBA 4000 slotted up front with Ferodo DS2500 pads
Using DBA street series blank discs on the back with Hawk ceramic pads
Also did a fluid flush and replaced with Motul 600 fluid
Bring on the next wednesday arvo sprint!
Mind sharing where you get them and what's the price?
will those blank discs at the back works well on the track, I got the 4000 slotted on the front, they works sublime.
but those OEM back rotors are all fuxked up.
So what I am concerning is will those blank discs = oem blank discs?
and whats the price you get it?
and the DS 2500 as well?
thanks =)
I didn’t go slotted on the rear for a few reasons
1. The guy who dose my brakes wasn’t able to get any slotted discs for a week and my rears "back left in particular" were shagged due to the pads being worn out and having metal on metal run groves in the discs
2. 70% of the hard work is done by the fronts
3. Slotting doesn’t actually do that much, its more about helping gasses from the pad escape and most new pads don’t have that problem
4. A better pad will have a much more noticeable difference than a slotted/drilled disc
So with that in mind and the new rear pads being ceramic = handles heat better. I didn’t see the need for slotted on the rear
I didint shop around with the pads price, I didint have the time to and could not be funked. My brakes were only working about 30% of what they were before I went to the track and I needed to get them fixed ASAP
Anyhow I ended up paying $277 for the DS2500 pads for the front $150 for the Hawks on the rear
I have used DS2500 pads on my old 180sx in the past which had R33 4 pot calipers/discs on the front. Compared to the 1st set of pads which were probally OEM nissan ones despite the brakes being fairly large given the weight of the car. I had fade after only 2 laps, after I changed to the DS2500 I could go the whole session 6 hot laps and not have any problems.
There is a sweet spot but when it comes to pads, if you fit pads that are too heat orieanted then they dont work as well when they are cold. The DS2500 for me work fine when cold but get better when theres some heat in them
Thanks for the information=)
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
