Man that was quick :)
I don't understand that though, why would it not? Voltage drop on 2.5mm wire that is 3 maybe 4 meters long would be minimal. Resistance in series would reduce current flow, wouldn't do much to voltage. Telephone wire can flow 125v down the wire the size of a string, just low current.
I don't see how there can be anything wrong with the wiring if the pump isn't blowing fuses?
  • Replies 41
Nah man maybe it refers to the pump need more voltage I.e. Stock pump - 12v, walbro - 14v.
And yeah didn't mean those thng as literal suggestions, just that 'rewire' could mean anything, need specifics. I wanna know too, I've got the same pump and have installed it with standard wiring.
What most do is use the stock wiring to power a relay and then run a direct wire from the battery to the relay and then from the relay to the pump. Idea is that once the ignition is triggered it will power the relay and from there the voltage from the direct wire from the battery is sent to the pump. You will notice the difference in the pump, it will sound angry with buzzing and the voltage which would have varied from say 11-13 volts should be somewhere from 14-15V. Remember a 255lph pump getting 11V will not push the same amount that one with 14V. On my GTT when I used the stock wiring my pressure would fluctuate due to the circuitry and my reading for my pressure was 20psi, now I get 40psi constant and my walbro makes a nice buzzing sound. Check the rating of the walbro to see as well, the recommended voltage should be 14.3V or somewhere up there.
I don't see why it would vary so much though ^ You shouldn't see a voltage drop of more than 1v from your battery. You would never see as high as 15v unless the regulator in your alternator is stuffed. Optimal charging is between 13.8v to 14.2v, so that is the max you would see at the pump. But even so, with the stock wiring you should not lose more than 1v, if that. So you should be getting between 12.8v to 14.2v at the pump, wouldn't matter what wiring you have.
Maybe if we were talking about current it would make sense, but voltage is the same.
The GTT has a built-in voltage regulator for the pump, what happens on idle and in traffic is fluctuates the voltage. You can check for yourself if you want simple measure the voltage you get through the circuitry to the pump and measure the voltage from running a direct to it, let me know the difference, this is a known problem not something that was unique to me :).
From what i understand the aftermarket pump requires more voltage than the stock pump does (12v), the ecu is only sending that much voltage down to the pump.You're not getting the full performance out of your pump even though it runs the car fine now.
Edit due to replies: I have also read that the aftermarket pumps don't take the ecu voltage changes well (idle, WOT) and another reason to run a relay.
Edited by Socrates
Nah man it's not varying or loosing power, the computer gives the pump variable voltage, but they need constant 12v to be tuned/used correctly...
TriniGT solved it for me, I get it now...
The GTT has a built-in voltage regulator for the pump, what happens on idle and in traffic is fluctuates the voltage. You can check for yourself if you want simple measure the voltage you get through the circuitry to the pump and measure the voltage from running a direct to it, let me know the difference, this is a known problem not something that was unique to me :( .
Ahaa, that's what I was looking for. That regulator would be the reason that I couldn't find lol.
But, who says that aftermarket fuel pumps require higher voltage? I can't find anything written by Walbro stating that they need a higher voltage, you would think that if it was going to make their pumps run better then they would make sure you knew about it.
Thanks for the replies, they are answering my questions :)
Yeah, but Martin's question is, how does one re-wire the pump to provide moar power?
i.e. 'rewiring' could just mean replacing the wires that feed the current to the pump, or changing the voltage source to a constant 12v, using a voltage amplifier, adding resistors etc...
No, that is not what he asked. :)
Get the mutlimeter out then, and see for yourself @ idle, under load etc. It's not always enough.
1volt loss to the pump can mean quite a bit in terms of volume.
Check the manufactuers info.
Bosch quote thier pumps running voltage that is higher than factory.
Walbro are the same, they need more juice.
Thanks guys, makes sense to me now :)
I wasn't aware of the voltage regulator, which is why I couldn't understand how there would be such a high voltage drop. Unless you had a regulator, the voltage is always going to be the same.
Will look into rewiring my pump now :(
I'm in the same boat. I have the walbro installed at the moment with stock wiring (I've also seen my car make 266rwkw on this pump setup with 12-1 afr's)
But maybe I've one of the lucky dip good pumps that can supply that kinda fuel at ECU supplied voltage...
I've got some cable and a relay and on the cards is take the car apart and run that cable to the boot for the pump, sigh.
Does anyone know the current draw of these pumps? would hate to have a relay not capable of switching the current and fuse together, or worse blow out :)
This is why the nismo drop ins are the best no issues no hassles just drop it in like the stock one and your all done.
You can just drop these pumps in and you are done but they won't function optimally, the nismo one might operate at a slightly lower voltage but old dodgy wiring can still be an issue. Personally I would spend the 30 minutes running a new 12V cable from the fuse box and then power a relay via the stock wiring, gives you piece of mind and you know it will last, really isn't any work at all, a few crimp connections, pull the carpet sides up and cable tie all the cables up.
No, that is not what he asked. :dry:
Did you really need to point that out mate?
All I was saying is that Martin didn't understand the concept of 'rewiring' the stock pump, cos no one had explained that it needed DIFFERENT voltage.
It seems you just went out of your way to shut me down.
Just sayin'!
Apologies for barking up the wrong tree in advance.
I did understand that it needed different voltage, I just didn't understand how the voltage at the pump could be less than what was at the battery because I didn't know about the regulator :dry:
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
