Whats The Go With V35 Sedans? No One Like 'em?
Does the steering feel heavy when you turn the wheels? Any puddles of fluid on the floor or that you can see leaking from anywhere? You could try bleeding the system, if it’s making a whining sound when turning the wheels then that’s a sure indication there’s air in there somewhere. Start the car and remove the reservoir cap, then turn the wheels from left to right a few cycles and then check if you see any air bubbles rising to the top of the reservoir. Top up if necessary and repeat. Otherwise, I can only suggest that your pump veins have seized or that there is a perished seal somewhere??
The jack holds itself in place. You slip it down into the receptacle and give the input a twist to open it up a little and jam itself in there.
I searched , but did not find what I need, I am mainly looking for where the jack fits into bracket in rear left trunk/fender bracket on a GTT and what holds it in place.
