Hi all
Just wondering what people have done about installing a catch-can in an r32 GTR with an rb30dett. I had an autech-style one (big tubular one) sitting above the cam covers but with the rb30 in there, there is no chance of getting the bonnet shut.
I am on a low-boost run-in tune at the moment so hooked up the factory style setup but would need to sort something out before final tune.
Any recommendations about what you've used/bought/made yourself, and in particular photos, greatly appreciated.
Cheers
Andrew
  • Replies 51
Posted Images
Grab yourself a set of Mines cam cover baffles. These will greatly reduce the amount of oil vapour coming out. Then you can keep the standard setup.
I have these, they did nothing....sorry to say. I run the Pro Vent catch can with the return into the dipstick tube. Its a real catch can not just a shiny empty can.
Pro Vent 200
They are cheapest off ebay
Pro Vent 200
looks good
do you have any pictures of it installed?
Pro Vent 200
You must have a fair bit of blow by then.
Myself and a friend of mine put a set of Mines baffles in both of our engines (both making over 400rwkw) and vitually stopped any oil vapor getting to the catch can.
i run a border catch can which i got from rhd japan then modified as directed by rob @ rips.
the correct way to run a catch can is to have both cam covers run individual lines to the top of a catch can which should have a filter, then run 2 seperate lines from the catch can (1 at bottom & another at mid point) back to the side of the sump so that it runs back into the sump
Pictures tell a thousand words ;)
The two lines back to the sump.. intake side? above oil level or below? seperate fittings on sump?
Thats what I though, leak down is less than 2% however. I think my issue was more an excess of oil in the head and-or to much Vac return. I am running the 1st breather from the high side of the drivers cam cover now instead of the low side on the passenger cam cover. Same as the Mines R34- dual catch cans (in series) Still returning to the intake. The PCV return has been blocked off. Will post up a pic later if you like.
Closed loop system to keep it 'more legal'
Edited by BoostdR
sorry bubba - 2 lines run from the side of the catch can back to 2 fittings in the side of the sump, at the highest pt of the sump
Hey Marko how's things?
2 lines back to the sump? that's a lot of drainback. almost sounds like its one line from the sump to let it breath (the one that goes in mid point) and the other is a return line.
that is exactly right mark :blink:
That's how I understood it too..
My head already has the vent on the back so I will be going 3 hoses to the top of the can (2 cam covers and the vent from the back of the head) then I'll do it how Markos is, vent sump to midway up the can and drain from the bottom.
that would work
That looks just like the NISMO oil air kit which plumbs into the rear turbo oil line and looks pretty neat aswel I might add
The nismo Doesn't work on an RB30 block...with the turbo bolt-on return anyway. Def the go on a 26
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
