Hi All,
Pulled the Haltech Platinum Sport 1000 out of my Evo 8 JDM which is less than a year old. This ECU is compatible with any car. Haltech offer looms to suite other vehicles with great local after sales support on their products.
Item comes with:
- ECU unit
- Map Sensor
- Data cable
- Haltech Sticker
- Wiring harness
- Patch loom for Evo 8 JDM
Item features:
* - Fully user-definable 32 x 32 mapping ( Up to 1024 points)
* - Wideband "Auto tuning" using user definable target AFR table
* - Narrow and Wideband closed loop O2 control
* - Staged injection control for multiple injectors per cylinder (inc rotary)
* - 3D mapped rotary engine ignition split
* - Soft and hard cut rev limiter
* - EGT fuel correction
* - Tuning via TPS with manifold pressure correction
* - Dual map switching for fuel/ign/boost
* - Anti-lag (Rally and Launch style)
* - Rotational idle
* - Launch Control
* - VTEC cam timing control
* - VANOS cam control (intake cam only)
* - True variable cam control supporting late model Toyota's, WRX's and EVO's
* - Dual intake runner control
* - Onboard 2.5 BAR MAP sensor (or use with external MAP up to 10 BAR)
* - Custom sensor calibration (Use your own sensors for temps or fuel/oil pressure etc)
* - Open or closed loop boost control ( Road speed, RPM or gear based mapping)
* - Closed loop idle control (Stepper motor and BAC type)
* - Extra injector control
* - Thermo-fan control ( Duty cycle or on/off )
* - Intercooler fan/spray
* - Alternator control (Mazda)
* - Engine control relay function
* - Nitrous switching with fuel / ignition correction
* - Staged shift lights
* - Aux fuel pump control
* - Tacho output (5v,8v,12v)
* - Turbo timer
* - Torque converter lock up
* - Air con request idle up
* - Windows 2000, XP, Vista compatible software
* - "In the field" updatable Firmware provides all the new features as soon as they are available
* - Onboard and laptop data logging with Data Viewer software
* - USB communication with laptop/PC
* - CAN Bus port for direct plug in communication with Racepak and Aim Dash system.
Condition: Excellent working order
Price: $1300
Item location: Sydney, can ship interstate/overseas at buyers expense
Contact Jason: 0423 324 906 / [email protected]
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
    • You just say that the premium increase seems particularly excessive (no pun intended) and that the value decrease seems unwarranted. You say that it's not 2005 any more, and that these days Skylines are generally owned and insured only by those that have demonstrated an ability to keep them in one piece across decades, and are therefore not the horrible risk that used to be assumed. etc.
    • Have a look at JS Performance Garage, just did a bit of work on a 32 GTR.
