Hello
Wrecking Late 1991 GTR except engine, Great Quality Happy to post or courier, Brisbane based Feel free to PM, text or call leave message if I can’t answer. 040818877. If someone is low hassle nice & fair I am happy to help. I have a day job so I am no car expert just enjoy Nissan's, please describe requests in PM title. Off the cuff questions please PM. Yell out as I have other parts that I have not listed e.g 33 GTR Turbos etc
Regards Taylor 0408 188 777
Panels
Guard Driver side 275
Left door 200
Side Skirts 250
Window mechanism 100
Rear Bumper 175
Rear Reo 175
Glass
Rear windscreen with all wiring, Genuine thinner and lighter 525
Light & Indicators
Tail Light Passenger side 75
Tail Lights Driver side 75
Interior great condition
Centre Console with lid 135
Roof lining perfect 90
Gauges
Greddy Exhaust guage and wiring 120
Climate Control 90
Drive Line
Gear Box 33 GTR Good condition fits 32 as well 850
Front Diff 250
Rear Cradle 400
Tail shaft 200
Suspension
Lower control arms factory with N1 brake ducting 100
Rear hubs 130
Engine Bay
ABS Unit 290
Brake Master clyliner 150
Power Steering Resivour 90
Coolant bottle
33 GTR Blow off Valves 175
Fuel Door 50
Fuel tank $40 90
Front sway bar 90
Front LCA (pair) 200
4WD Computer 150
Engine Harness $600 new 120
Injector & resistor pack 120
Air flow meters 145 Each
HKS air pods 80 Each
Centre Console 160 set
Gear & Hand brake Leathers Genuine Perfect 85
Exaust 400
Feel free to PM, text or call leave message if I can’t answer. 0408188777
why is this not in sa hell crazy parts
Hi
I am happy to post or courier depending on the size at good prices. I make an effort when packing with load of padding etc
Cheers
Hi
Sorry for the delay in text messages I had a back up and a bunch came thru all at once. Just to clarify items available are from the list above injectors have been sold. There is some of the smaller parts that I have not listed
Cheers
  • 4 months later...
taylor,
front subframe (engine one) $? need one for mine.
also radiator guides - think there are 3-4 of them -$?
Do you have the black plastic surround for the centre triple guage cluster. I am leterally after the black piece with the three holes cut out for the guages.
If so is there any damage on it and how much posted to sydney?
Thanks.
Can I have the following:
1) both back 1/4 window interior surrounds - only if good condition
2) drivers seatbelt
3) cabin temp sensor in bottom right of stereo, aircon, 3 gauge surround
4)sunload sensor in corner of bottom left windscreen and top left of dash
Let me know prices as I guess it all comes under interior?
stock boost solinoid shipped to melbourne ?
Hi Guys
I just need to find the solinoid, vents and cabin sensor and I will be in contact.
