Hi everyone
I have the following items for sale,
1, R34 GTT Bilstein shock absorbers with Kings spring. Those shock are in good condition; no leaking. Selling it due to upgraded to coilovers
Price $350+postage
2, H1 size 8000k HID light bulb, a pair. Those bulb are brand new and was order for my car but won't fit in the xenon head light
Price $35 with postage
3 H4 size 8000k HID kit (with High and Low beam). They are 90% new just test fit the bracket into the car, light bulb and ballast have never been use. This kit is only use as a business promotion.
Price $145 with postage
Items are located in Brisbane, if anyone interest please send me a email [email protected] or send me an SMS 0424459279,Thank you
https://www.sau.com.au/forums/topic/333973-some-new-and-old-parts-for-sale/
No they off my 34, I believe they are the optional upgrade for my car, because there are some jap writting on the shocks. I am not sure about the model number but I find a set of number under the front and the rear coil.
Front: E4-FT2-Z003A01
Rear: E4-FT2-Z007A00
More info the shocks are traveled about 50000k and the Kings spring were in the shocks around 48000k, although it had done a fair bit of distance but the mechanic said they are still in good shape. All the inspection and installation were done by Centrax Brisbane, the Endless official disributor.
Hope it helps!!
I take it they arent the sydneykid bilsteins? what are the model numbers on them?
Cheers
I mean the kings springs were installed at 48000km and the total of the shocks had traveled about 50000km.
Hope it helps!!
Do you have the standard springs for the shocks? any idea if they are lower than standard suspension (with the original springs)? I'm interested but would rather have the shocks matched with the springs that they were matched to
guys bilstein shocks now $320!! Please need them go away
and Just find out the hid kit is missing one of the bracket, it will be $80 for the set
  • 3 weeks later...
  • 5 months later...
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
