R32 Gtr - Gtst Parts - Leftovers From Several Cars And Shells
Help me get my shed back in order. Need to fund a new wakeboard!
HKS VPC. Come with everything. Use this to remove your AFM's on your gtr and still run std or pfc ecu $400 Allows control of fuel mixtures to make your car run safe AFR's. Uses its own Map sensor and inlet temp sensor plus all std motor sensors. Removed to return a GTR back to standard to sell.
Set of front guard liners and front under tray. Has factory front brake ducts and I won't seperate. $150 Getting very rare!
RB26DETT oil pump $80
Box random RB26 bits $50. Need to see whats in there. Won't respond to Pm's about this yet.
RB26 block. Good for coffea table. Has a cracked water jacket into head bolt hole. Could re-use it for a std build without any probs. $50 Didn't use water or oil before disassembly.
R32 GTR fuel pump in cradle $80 each.
R32 3inch exhaust with seperate de-cat pipe. Has centre muffler, no rear muffler, just straight throught to out back $100
R32 GTR body fuel cap/flap $30
R32 GTR ABS mater cylinder $75 Below is another full setup
R32 GTR full ABS system- Master cylinder, ABS unit, All related brake lines $275. Would swap for non-abs setup plus small cash adjustment my way. Still in car and work well. Removing to strip weight for track car.
R32 GTR G-Sensor $100
R32 GTR rear diff and GTR driveshafts. Perfect upgrade for GTST? $450
R32 push type 4 puck solid centre button clutch w/looks like custom pressure plate and std flywheel. In VGC. Appears like it hasn't been used much since new. Heaps of meat $400 lot. Will fit all push type RB series motors.
New R/H sill panel $100 Suit GTR/GTST
R32 R/H tail light $30
R33 GTST original/genuine JUN front bar. In good condition, need a couple little bits of fibreglass. Looks like a 400r bar but better. $250. These are bloody expensive new. Currently in white with blue pearl.
Pair Volk Circlar rims 18x9.5 +38mm offest. $300. One painted spray can black. I know where there is another perfect pair for $500 if needed. These sell for around 1500-2000 set. I can't be bothered.
R43 R/H mirror $25
R33 GTR lowered rear springs for std style shocks $50 sits very nice
Set Tein stiff springs. Perfect for drift. $30
Pair headlights for R32 gtr but will fit gtst. Removed the glass from one body. Stil have it. They have a few broken mounts but still worked fine. $40 pair.
Melbourne 40 min south city. Can post. Please no time wasters. You know who you are!
Hey mate
Just a bit of info. A while back when the diff in my R32 GTS-T was buggered, i looked at putting in a GTR diff. I didnt do it because apparently my diff is mounted with rubber mounts, while a gtr diff is solid mounted to the body. It was gunna be a lot of work to make it fit.
I was told that by a reputable workshop i take my car to for major works when i dont have time for it myself, hope that helps with that part....
hey mate can i get pics of the jun front bar and would you be willing to post to mackay qld 4740
I can post it anywhere at your expense. Don't know about frieght prices. Jump on some of the bodykit supplier sites if you want a rough estimate.
Hey mate
The gtr diff is also rubber mounted. From a quick search it look like you would need GTR hubs. You can still put the GTR diff centre into a GTSt to give it a mech diff.
Just to clarify the 32gtr diff is a staight bolt up (IF) used with a 32gtr subframe,so to fit to a gtst you will need diff,shafts,subframe & hubs as gtst suspension & arms are a direct bolt up to gtr subframe, to use gtr uprights you need gtr rear coilovers.
Just some info since i have done the job before.
free bump >_<
Edited by jas/slo32
Hi,
Would you sell just the two franges (Tongues) from the GTR32 diff.? I am from Mordialloc 3195 can pick up 0433 878905 Alex
R43 R/H mirror $25
hey mate ill take the front bar if you want to pm me with the exact total including shipping and your payment details
cheers Fritz
I'll have to get a price on shipping and also work out how to pack it so it won't get damaged. You've saved me a heap of hassles and weekends. It was going to get the chop and go on my 32 gtr.
Tim GTR did you forget to write something?
Pair Volk Circlar rims 18x9.5 +22mm offest. $300. One painted spray can black. I know where there is another perfect pair for $500 if needed. These sell for around 1500-2000 set. I can't be bothered.
Editted offset to +22
Its only letting me send one pm per hour again so if people can attach email addresses to their pm's it will help speed things up.
I'll take the diff without the flanges (tongues) that TimGTR wants and without driveshafts if you'll go $150? Just had a pinion bearing go in my Sil80.
Won't be seperating it atm. Might be selling the car so I'll use it to keep the AM diff in it.
Hey I'd like a price on the splash guards and brake ducts sent to Sydney
Thanx brett
Not really worth me selling an item for $100 and then have to drive 20mins then back to drop it of in work time.
 Share
