Oh hey guys, I'm having a bit of trouble with my motor vehicle atm and im needing help...Here are the details of my vehicle:
R32 GTST
Rb25neo det (original turbo, ecu, etc.)
Rb25 gearbox (R33 box)
Random fuel pressure reg.
Boost t-piece
Bosch 400hp fuel pump + surge tank
aftermarket intercooler + piping
Heres the problem,
The car idles fine, sounds perfect, feels perfect. revs fine no worries standing still. When i drive its fine, until i hit about 2-3psi of boost. at this stage the engine starts to missfire like a tard. If i keep flooring it and manage to push to 5-6psi the engine stalls.
Things i've done to try and fix the problem:
Upgraded my fuel pump to the bosch 400 hp, originally thought there wasnt enough fuel getting to the engine. After installation problem got worse. I bought new spark plugs and made sure they were the correct gap. no change. Rreplaced all the rubber pipe connectors for the intercooler pipes as they were old and some had holes. Problem is stil aparent although now i have a sweet dose sound >_< ...checked all my vac hoses and such...ive visually inspected coil plugs and found no signs of cracking or burns from arcing out but will check tomorrow propperly...
other random problem:
When i first drove the car with the new engine in, i noticed the wastegate to the turbo was opening straight away. ??? i borrowed my mates t piece to combat this??? maybe this has something to do with the problem im not sure...
I would really appreciate advise as im sick and tired of seeing my car on the side of the road...WANT TO CRUISE!!!
Thanks, Edward
https://www.sau.com.au/forums/topic/333996-r32-neo-disaster/
it sounds like its leaking un-metered air in somewhere...
if you take the vac line off the pre intercooler pipe (just after it leave turbo ill c it..)
stick a normal size can of tomatoes or sumthing in your intake... tighten it up air tight.
pump up the nipple with a bike pump to what boost your running... let it sit there for a bit, it shouldn't leak at all.
alternatively, ur really chasing a leak i believe... so wack a bit of pressure in it.. and listen out... if your finding it heaps hard to find a little trick is to use a hose, and put one end to your ear, other end to what ur listening to... will amplify the sound...
obviously do this after checking all the usual clamps afm is bolted up nice etc etc...
I had a similar problem with mine when I installed an aftermarket fuel pump & wound the boost up, turns out the std injectors were bein pushed too hard with larger than normal fuel pressure & were in-effective at giving a proper spray pattern at low rpms but would come fine once the motor started to rev to.
Dont know if that helps or not
To fix it I got a Nistune-new injectors(660cc), changed fuel pump from Walbro to a Nismo pump, added a Sard FPR, changed plugs to copper & gapped the plugs to 0.7mm
Changing pumps does not affect the pressure at the fuel rail as that is governed by the fuel pressure regulator (hence its' name).. UNLESS the old pump had inadequate pressure and the ECU was tuned around this.. then by fitting a properly operating pump the fuel pressure goes back up to what it should be but because the ECU was tuned around the old pump, there is suddenly a lot more fuel going in.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
