Hey guys, i just wanted to see if there is any interest in having their car stripped back via soda blasting? My partner and i are getting to the stage where we want to take control of our own income instead of relying on someone else to tell me how much i can earn lol. We're in the process of trying to organise finance and equipment and will hopefully be all set up and ready to go within the next 6-8 weeks. So we're basically testing the waters here to see if anyone is maybe building their latest masterpiece and needing to strip back the original colour, building a racecar that needs blasting inside and out or even someone who has their own industrial equipment that they want cleaned down/stripped for repaint. Or even stripping single panels for repaint. How much realistically you would spend in having the whole car stripped or even just stripped for a doors shut respray etc would be helpful too. Any other questions you can pm me etc or just reply in this thread. Thanks guys.
Btw, for anyone else that jumps forums like i do, yes i've asked this on other forums as well. Just looking for some info and a bit of indication of potential customer thoughts/needs.
https://www.sau.com.au/forums/topic/334047-starting-out-in-soda-blasting/
Whereabouts are you? I've got a couple of small flaws which I'm looking at getting fixed in the future. I dont mind showing you and getting a rough idea on how much it'll cost. Maybe PM your number and we can arrange for something next time I'm back in town.
  • 4 weeks later...
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
