Hey everyone,it's time to let go of my pride and joy. The reason I'm selling is that I just dot have enough time for it anymore and need spending money for overseas trip next year . This would be one of the cleanest 1994 r33 out in Sydney.
I have owned the car for 4 years and I'm the 2nd owner since it was personally imported into Australia. The first 2 years it's been in storage in my garage which was started once a week and taken for a drive around the block to keep all the running gear in working order.
The car was also Resprayed 4 Christmas ago ( Ford perlecent blueprint blue) and still is in pristine condition. It has an original r33 gtr front end, everything was done properly for the conversion from gtr bonnet hinges to the gtr bonnet latch, front reo and headlight spacers, this cost well over 4 grand for the conversion. It's a one of a kind gts. As for interier wise its in very good condition, all the trims and dash are straight and always conditioned. There is a cigi burn on the roof and one on the back seat from the last owner as I'm a non smoker and the drivers seat moves a bit but is still in very good condition for a 16-17 year old car
The car has never been in a accident and is clear on revs. There's around 3-4 unnoticeable small dents around the car but can easily be fixed. No rust spots at all as it's common for older skylines.
The r33 has always been serviced every 5-7 thou k's and gearbox and diff at 20thou k's by yafuz @ unigroup engineering a very trusted workshop, and no expense has been spared. Average round 400-450 km out of a tank which is very good for the power it makes. Always premium fuel used (shell v-power). Has a nice cat back exhaust system that's not loud at all just a nice rb growl.
Plenty of money spent on this car to get it how it is today, save time and money and buy a soft/mild tuned economic and reliable car. Also has top of the range mongoose m80s alarm.
That's about it, posibly one of the cleanest r33s on the road and needs a new owner to get some use out of it show it off.
Engine:
130xxxkms
Apexi PFC ($1200) tuned by yafuz @ unigroup make a safe 191.3 rwkws (tune cost 700)
Apexi boost controller ($430) max set to 12 psi ( always driven on low boost 7psi)
Hybrid front mount intercooler with saber fittings and clamps
Apexi intake filter
Highflow cat/back exhaust turbo world muffler
Greddy type s plumbed bov
Can supply most stock parts including ecu
Suspension/brakes/body
pedders shocks and lowerd springs ( front right knocks a little bit , can hear it sometimes when I reverse out of my driveway won't hear it anyothet time was going to replace with coilovers any way)
Front strut bar
New front brake pads
Resprayed 4years ago blueprint blue ($6.5k job) looks stunning after everywash
Front half gtr conversion ($5000)
Series 2 spolier
Explosive sideskirts bought from team jet speed
Will come with a trial rear bar unpainted bought recently ($240)
Price: $15,000 neg with 1 year rego
Contact: tilla 0402362885
Not interested in any trades atm
And needs to sell by the end of year so plenty of time.
please no time wasters as I'll can spot you out a mile away :(
Please don't comment unless interested cheers
Pm me for more pictures
Forgot to mention it has:
excedy twin plate clutch hard to get use to but very nice bitey clutch worth ( $2300)
5% tints all round with life time warranty
Mint original gtr rims with 70% tred
Hks turbo timer
Front foot well leds
Cyber stork white gauge dials
Greddy boost pillar with apexi el boost gauge
And havnt got a head unit for it as the other one stuffed up but has clairon 6 inch splits at the front and rca cables ready for amp and sub
And that's bout everything
Cheers
  • 3 weeks later...
  • 2 months later...
$13,500 rego till mid next year
new excedy clutch
machined flywheel
machined all rotors
new front rear pads
just spent another 1500 on it!!
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
