hey man just had search but i couldnt reli find what exactly i was looking for...i just need a quick answer...is it a big job to put a rb30de bottom end onto a rb25de? n will help me run higher boost more safely?
plz plz plz
The correct CR will help you run higher boost safely. so while u got the RB30 block apart, replace the pistons for lower CR, just grab a set of VLT pistons, they will be fine. if you read thru the rb30 conversions in the "forced induction performance" section, you will notice it isnt sucha big job.
if anyone is planning to do this, i have the stock R33 intercooler and piping for sale atm, for $80 ono. just pm me, its all in very good condition btw.
Don't be fooled gents. its not only the compression factor, but the piston itself, the N/a pistons are not Hyperputectic. therefore, even with low boost pressures, after a while you will melt a piston.
By all means, do this upgrade! turbo is 100% better effecient power, than most other mods. But do plan to change your pistons over in the near future.
Not really, my car ran fine for a over 50,000kms and as far as I know is still running fine without ever being cracked open to change pistons.
Melting pistons is from a poor tune, you can do it with any engine
the cast pistons will not tolerate the higher combustion temperatures associated with boost.
of course a good tune will help keep detonation to a minimum and the correct supporting modifications will ensure oil temps and water temps are kept low, but eventually the pistons will give up the ghost.
an example is my good friend who has a famous AE86 drift car here on the gold coast.
He had a stock 4AGE bluetop (bigport) bottom end which has the smallest rods, crank and gudgeon pins of all the 4AGE's and it took 6 months of punishment from a HKS GT2510 at 13 PSI pushing 150 kw at the wheels out of 1600cc.
It had a great tune from Adam from JEM and had all the supporting mods like a alloy radiator, great intercooler, big fuel system and oil cooler. The water temps never got above 82 and the oil never about 90 - 95. Eventually, the pistons gave up. But it goes to show that a motor can be pushed to nearly triple its factory power and still last for a while given that the correct supporting mods and great tune are applied.
Side note: I have read that the turbo RB30 pistons with the twin cam head will result in a 7:1 CR. too low
hey i just though i would go back a little bit and add something in, in relation to drilling the oil return line into the block a way of getting around this would be to buy an oil cooler and run the oil lines from the oil filter to the oil cooler to the turbo out the turbo then into the engine and around agian, this way you would have the best oil going to the turbo and you wouldnt have to worry about drilling holes in the block, and as a bonus it would be even easier to return to stock if needed
  • Like 1
13psi in a 10:1 is asking for trouble that would have contributed to the death of that engine...I owned a blue-top as well and managed to melt the piston without a turbo.
under 8psi with stock pistons will see a reliable engine that won't need forgies and will live a long prosperous life.
ive got vacuum hose running straight from the compressor nipple to the wastegate actuator and its natural boost is .8 bar.
i do have a bleed valve in the line but its completely shut. i might delete this as it may still be causing a boost increase.
If you've got an RB20 turbo that's normal though, the actuator I put on my highflow from an RB20 was 13psi straight on the actuator, no bleed valve.
Grab one from a series 1 R33, it should be nice and tired and give about 6psi
Absolute bullshit, my series 1 25de had the oil return just above the sump blanked off which simply unscrewed to fit my return line fitting. The same as the water return and oil feed, the only thing I had to source was a water feed which I t-pieced from a heater hose. Piss the rb20 crap off, accept a 25det stock turbo as a minimum.
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
    • interesting....sounds like the later trans has software differences (or AM vs JDM). If I wasn't going down the tuning route it would be worth looking into retrofitting a new computer to the old box.
