Im gonna run 10, thats my absolute limit. Im running 6.5 atm, car spools nicely. Its weird having it on boost at around 2200rpm, then thinking, gee this is pulling hard, then that weird ass top end power comes on and your off twice as hard. Great fun
Yeah I had the same with my car, it was bizzare...the top-end was impressive
  • 5 weeks later...
For anyone interested in doing this conversion, I made 210rwkw and 475nm on Dr drifts dyno today @ 9psi with stock injectors, stock ecu & stock R31 fuel pump, cooler and high flow t3/4
Edited by juddieR31
666Dan, how much boost was the turbo making from off idle?
I've worked on a few RB25DE's which have had RB20 turbos fitted to them and they were practically making boost when idling. Massive torque down low but runs out of top end very quick... One of those cars now runs a fairly insane turbo/setup (still high C/R for response), makes about 300 rwkw or so, that was done nearly two years ago and its still going, really needs good tuning to keep them together....
hey man, i wanna turbo my r33 rb25de what computer do i run, some ppl say rb20det and some say rb25det, some say the rb20det wont work with the vvt etc and the rb25det is too hard to tune, im confused i can get all rb20det parts real cheap but dont wanna do it unles i know what ecu will plug in and work, can i get away with just a std turbo ecu and tuning and no link or safc etc as im on a tight budget, only want to run stock std boost...
cheers guys
my sugestion is if your on a tight budget then wait until you got the money to do it properly, you never know what might go wrong and end up costing you shit loads to rectify, as for ecu, i would not sugest any standard ecu as it will not be safe to drive, possibly a standard TURBO ecu with a piggy back, but aftermarket is always best, as for r32 ecu it will work but i think something has to be done to it to make it work ie some pins have to change or somethingh and it will need to be re-mapped and you will need an aftermarket cam controller, dr. drift suply and fit r32 re-mapped ecu's with cam controler for around the $1300 including dyno time, or you could spend the extra 500ish for an aftermarket unit tuned,
As these guys have said, if you're not after full tunability, the stock ECU is fine..generaly the tune on it is quite well suited to the higher compression. Stick and SAFC/emanage on it if you want to adjust a bit more.
I have just finished my turbo conversion in the uk and made 310 bhp and 275 lb/ft torque at 9psi would highly recomend this conversion to any one . Thanks for the idear and info 666DAN with out this forum and your info i would still be driving a 200ish bhp A/N and wanting more power . So thanks again :O i have added a pic of what she look like .
hey mate wat mods do u have in ur car to make that sorta power?
Hi mate i have a 100mm front mount intercooler and hard pipe kit , GReady E01 with Emanage , FSE fuel pressure reg and fuel pump , Gready turbo elbow down pipe cat pipe and 2" N/A nismo exhaust , Apexi oil cooler , HKS and Green induction kit with cold air feed , engine circle earth with voltage stabeliser , uprated blow off valve with about 4 hours on the dyno and in the process of fitting 25 shot of nos and intercooler sprayer which should give about 40bhp on top of the 310
    • Yes there is a front and back insertion point on each side, each point is tubed with supports into the car and tied to the cage/ floor mount point
    • Is the jack stand system tied into the cage somehow? Upgrades look goooood 😍
    • Big updates, tons of work and $$$
    • it takes so long to get things done but ... they are nearly there and we hitting the track soon again  So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one     At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order     While all this was happening the new MCA golds turned up and did some fiddling around with those   Put in the flappy paddle system and clutch lockout wiring/ system   We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth   Looking for better control and faster acceleration     I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time      making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier     All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon   So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical   We'll see how all this goes
