Im gonna run 10, thats my absolute limit. Im running 6.5 atm, car spools nicely. Its weird having it on boost at around 2200rpm, then thinking, gee this is pulling hard, then that weird ass top end power comes on and your off twice as hard. Great fun
Yeah I had the same with my car, it was bizzare...the top-end was impressive
  • 5 weeks later...
For anyone interested in doing this conversion, I made 210rwkw and 475nm on Dr drifts dyno today @ 9psi with stock injectors, stock ecu & stock R31 fuel pump, cooler and high flow t3/4
Edited by juddieR31
666Dan, how much boost was the turbo making from off idle?
I've worked on a few RB25DE's which have had RB20 turbos fitted to them and they were practically making boost when idling. Massive torque down low but runs out of top end very quick... One of those cars now runs a fairly insane turbo/setup (still high C/R for response), makes about 300 rwkw or so, that was done nearly two years ago and its still going, really needs good tuning to keep them together....
hey man, i wanna turbo my r33 rb25de what computer do i run, some ppl say rb20det and some say rb25det, some say the rb20det wont work with the vvt etc and the rb25det is too hard to tune, im confused i can get all rb20det parts real cheap but dont wanna do it unles i know what ecu will plug in and work, can i get away with just a std turbo ecu and tuning and no link or safc etc as im on a tight budget, only want to run stock std boost...
cheers guys
my sugestion is if your on a tight budget then wait until you got the money to do it properly, you never know what might go wrong and end up costing you shit loads to rectify, as for ecu, i would not sugest any standard ecu as it will not be safe to drive, possibly a standard TURBO ecu with a piggy back, but aftermarket is always best, as for r32 ecu it will work but i think something has to be done to it to make it work ie some pins have to change or somethingh and it will need to be re-mapped and you will need an aftermarket cam controller, dr. drift suply and fit r32 re-mapped ecu's with cam controler for around the $1300 including dyno time, or you could spend the extra 500ish for an aftermarket unit tuned,
As these guys have said, if you're not after full tunability, the stock ECU is fine..generaly the tune on it is quite well suited to the higher compression. Stick and SAFC/emanage on it if you want to adjust a bit more.
I have just finished my turbo conversion in the uk and made 310 bhp and 275 lb/ft torque at 9psi would highly recomend this conversion to any one . Thanks for the idear and info 666DAN with out this forum and your info i would still be driving a 200ish bhp A/N and wanting more power . So thanks again :O i have added a pic of what she look like .
hey mate wat mods do u have in ur car to make that sorta power?
Hi mate i have a 100mm front mount intercooler and hard pipe kit , GReady E01 with Emanage , FSE fuel pressure reg and fuel pump , Gready turbo elbow down pipe cat pipe and 2" N/A nismo exhaust , Apexi oil cooler , HKS and Green induction kit with cold air feed , engine circle earth with voltage stabeliser , uprated blow off valve with about 4 hours on the dyno and in the process of fitting 25 shot of nos and intercooler sprayer which should give about 40bhp on top of the 310
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
