I have just finished my turbo conversion in the uk and made 310 bhp and 275 lb/ft torque at 9psi would highly recomend this conversion to any one . Thanks for the idear and info 666DAN with out this forum and your info i would still be driving a 200ish bhp A/N and wanting more power . So thanks again ;) i have added a pic of what she look like .
Nice effort!!! Glad you gleaned some useful info from this thread :P It is worth doing and can be done very well as your numbers prove.
thanks guys just what i wanted to hear, i wont want to do any tuning or boosting, just want low boost to give some decent low down torque that the n/a sucks arse at.... so i should definately use the rb25det ecu, and what turbo will best suit the rb25de, the rb20 or rb25 turbo? and will i have to mod my loom at all for the turbo ecu
If you upgrade the injectors, fuel reg and fuel pump to GTSt spec, then the RB25DET ECU will be fine and be plug 'n' play. Bolt on an RB25DET turbo and run at stock actuator pressure and it should all work a treat.
Don't get a smaller turbo as it will spool *way* too early.
  • 3 weeks later...
It's not so much about the power numbers but the response with running an engine spec like this. Run with an intelligent tune there is no reason why it wouldn't/couldn't be reliable, possibly more economical, and with the sort of power that works well on the street.
That said, do we have any dyno sheets of any description?
Here's a graph of my RB25DET running 12psi to achieve 300hp. It's not overpowering, but very useful and responsive. The dip right at the top end is from pulling ignition to combat knock. I've considered that a well thought-out DE-spec engine with similar power numbers would be even nicer, response wise on the street. Perhaps water-meth is the key to making one detonation proof?
Edited by Dale FZ1
  • 1 month later...
how hard/difficult would it be to take out the rb25de from an r33 series 2 manual, and put in an rb25det engine and ecu?
what would be needed? would all the wiring match up? im guessing it wont....
any help would be great
This is the dyno sheet for my turboed RB25DE at 9psi
Edited by shawny
Hi Shawny,
Nice numbers. What mods do you have on your car? I am a new member here, from Canada, and have been having all sorts of troubles. If you can help me with stuff here, I would be grateful. I have an RB25DE with an R33 turbo on it, Trust FMIC, 370cc injectors, Turbosmart BOV and boost controller, with stock RB20DET ECU and Gredy E-Manage). Everything else is stock from my RB20DET days. Since they are new to Canada (how pathetic this is, lol), not many people know how to fix a Skyline, at least not as much as Australia or UK or Japan.
I am having troubles with idling (The TPS I am using is for the RB25DE, but my ECU is RB20DET, and the AAC valve is not working)....the cars sputters and backfires a lot, it hesitates under load and when I give gas. The power just doesnt seem to be there. Right now, after being dynoed once (260 rwhp), it has started sputtering between 2000-4000 rpm range, and the sudden bog/hesitation is still there. I dont know what is going on. What do you suggest? Also, please do share what youve done to your motor to get such impressive numbers. My motor also has the VCT on the intake side, but I dont know how to activate it with a switch.
Thanks,
Judas
Edited by Judasentinel666
  • 1 month later...
i have a neo st8 6 is it easy to fit a turbo on it i have been told
to Find a R33 with a turbo and fit it... (cheeper option)
and to fit a kit (if i can find one) will be around 13,000 bucks
but its hard to find one because the darn company went in 2 relaps and stop making turbos 4 the
neo st8 6
errr have u not read the start of the post dinobones? all u need is just a stock R34 turbo with FMIC/or SMIC with standard turbo computer and the oil lines tapped and water lines etc....then your all good to turbo and do something with the timing and thats it :P no need 13 000
CHeers
Chi
    • I did a pretty ruthless clean up before I left townsville. If it wasn't a part to suit a car I currently have it was sold or binned. I have all my stuff organised in big tubs with lids that stack from supercheap and bunnings depending on who was cheaper at the time. Parts were sorted by either chasis/motor/Fabrication/general/electrical. I have a mezzanine that's 7mx2.3m and all lives up there. Easy to access when needed and out of the way.  I also have the issue of selling and dealing with scumplace/marketbook was actually going to list stuff today but couldn't be bothered as been stuffed around too much. I generally let a few people know I want to off load stuff and people pass it on to others to contact me, generally easy sale and I'm never looking to make big dollars. Rather it gets used than go in the bin. Next clean up will be around Xmas and if doesn't go on the s15 it's going bar 2 sets of wheels.
    • Did a little bit on the V37 today. I bought this LED kit out of the US https://www.ebay.com.au/itm/125953603618. Best I could find online but didn't look great, in the end the quality was pretty much right and it did come with locations for each light including rear number plate and a few spares. The factory owners' manual was also useful with information on where to pop each light out without damage. I prefer the LED look as I use it daily including at night and the LEDs are both brighter and the white light is easier to read with. Vanity mirror comparison, LEDs just look more modern The glove box was the only difficult one (and the only one that was previously blown.....), steps were Open glovebox 50% but not fully open Push up on bottom of the box to unclip it on both side, not screws or pins to remove Remove the top stays at an angle, right side then left, because.... Before dropping the glovebox totally, remove soft close clip on left Then, remove 7 screws to release the glovebox surround Twist the globe holder anti clock to release it from the surround In this case, the LED globe supplied was wider than factory and did not fit, so I ground down each side about 1mm then inserted it Last trick, start engine to check the LED polarity is correct, the globe only operates when the engine is running (whether the box is open or closed) I also moved the 4G booster and wifi across from the Fuga, a little frustrating as I could not find a good Accessories ACC source anywhere in the boot so I'll run a wire from the cabin next time I get a chance. Also, unlike the Fuga the external antenna wire does not quite fit between the rear windscreen and the body so I think I'll have to drill a hole in the roof to mount it. Probably not that interesting for most people so I'll just post once complete
    • Pretty sure I could do but it would need to be exported and reimported as the current import approval is race only. But in practice there are plenty of other practical reasons it can't be a road car despite their potential value these days like stripped interior looms, cage to cut out etc Nah, no mods to it other than updating the roll age to current regs. It makes about 350 (laggy) kilowatts on the N1s at 18psi which is enough to push it around the place
    • This is it, folks! Our final event of the year... The big one, you all know and love - Putty Road! It goes without saying, but this is the biggest cruise in our calendar each year! A nice long drive, with a hearty pub feed at the end! Do you need much more enticing than that!?!? So make sure you wash the car, get your cameras out, block out the calendar, and get ready! We know you're all as excited as we are, so make sure you lock in the details and date below: Date: Sunday 8th December 2024 Meet Location: Corner Windsor Road and Groves Avenue McDonald's / KFC (3 Groves Avenue, Mulgrave) Meet Time: Meet at 9:00am for a 9:30am departure Destination: The Royal Hotel, Singleton (84 George St, Singleton) Map: https://tinyurl.com/saunsw-puttyrd Itinerary: We will meet at McDonald's / KFC on Windsor road and from there will head onto Putty Road. There will be a break at the Grey Gum Cafe (8679 Putty Rd, Putty) which we should reach at approximately 11:30am. For all the Newcastle folks this will be a good point to join up. From here we will continue on to Singleton for lunch. Please remember to fill up prior to heading onto Putty Road. There will not be a fuel stop until Singleton. To those running on E85, Freedom Fuel (old United) at Vineyard on Windsor Road has started selling there. At Singleton there is a range of servo's available including BP, Shell and Caltex. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back by popular demand - we're lining up another Old Pac Run! Get your cars ready for one of the best night runs on the calendar! So without any ado whatsoever, here are the details for you to save: Date: Saturday 23rd November 2024 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: Meet at 7:30pm for a 8:00pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://tinyurl.com/saunsw-oldpac Definitely an easy one for this cruise, meet at Cowan Truck Stop and jump straight onto Old Pacific Highway! Final stop at McDonald's which has plenty of parking all around. Please be mindful of the added police presence lately so best behaviour is expected! There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
