The part number for a r33 cat in a N/A and a turbo are the same. I would only be using an educated guess but i reckon its the same for the R34.
If thats the case the dump pipe will match the cat along as it the original one from compliance.
Ok so I'll run an r33 dump and front pipe into my current cat and other pipes (for now).
More questions, with the intake we have the na with the big Y piece. The Gtt had the single straight cross pipe. Will I need to buy a new intake manifold from a Gtt? Or do I bolt the cross pipe to the big Y thing. I don't know what to call it! Haha
I've attached pictures.. Hopefully they work with tappatalk!
attachicon.gifImageUploadedByTapatalk1379183368.667917.jpgattachicon.gifImageUploadedByTapatalk1379183378.351019.jpg
You can get a custom 90 degree pipe made up or use a silicone pipe and attach to the end of the "Y" piece. Dan666 has/had this setup I think. You will have to remove the resonator box and get a GTt airbox :)
Still going along.
Things to do:
Mount intercooler to get piping made up ready for install.
Source intake manifold/cross pipe/bov/throttle body - alternatively I could weld up some pipe with a bov and attach that to the big Y throttle body. What ever is cheaper/easier.
Dump/front pipe still need them cheaply.
ECU! What will I do there?! is the AWD controlled by the main ECU? From what I can see there is a separate AWD computer. Hmm.
P.s some background on me:
I'm studying Science, im 23, I used to modify computers when I was in my teens. I also used to race karts and work on them. This is a bit of a learning exercise for me, but I have a few mechanics helping me out when I get stuck.
Get a Ebay front and dump pipe in one. They are about $299 and will get as good as the genuine ones if not better, not much more than 2nd hand genuine.
Also look at getting a braied oil feed line and braided coolant feed and return line kits. You get all 3 lines in the kit.
ahk, thought you were using a RB25 turbo.
The oil return should be on the turbo you have, it stands out (Its a15 cm metal pipe with about a 45 degree elbow bend at the bottom of it aimed towards the bottom of the block so it drains turbo oil into the sump).
There simple drain pipes, if you didnt get one with your turbo that one on Ebay looks to be a good alternative, you just bolt that plate to the turbo and screw one of the fittings in then the other into the block fitting and hook the hose up and its done.
  • 3 weeks later...
I've got Turbo Yoda from Mighty Car Mods giving me some advise on this one. He's actually told me that because of the NA motor I can run a bigger turbo than you would be able to in the Turbo model.
For now I'll run the RB25DET stock turbo.
Higher compression spools the turbo very quickly. On my auto I would reach full boost by at least 2,000rpm.
I lost compression after 40,000 kms of N/A+t, and I didn't drive it gently either. I was going to do a stag n/a+t swap with a larger rear housing turbo, but decided on reliability of a det swap which on stock turbo and internals through a heavy duty auto box netted me 215rwkw with a e01 boost controller and emanage blue ecu running map and afm simultaneously, tuned by Paul Fisher at Pulse racing. I'd take the swap over bolt on conversion.
Still collecting parts here, getting a bit poor and uni exams atm!
If anyone has cheap:
Oil/water turbo lines
front pipe
SMIC with piping (can trade for a FMIC with no piping, but its big and will fit the skyline front grill just haha)
what are people doing for the oil drain on a s1 r33 25de engine?
i'm thinking weld barb onto sump as its cheaper and quicker then drilling and taping in a new drain where that blanked off one is on the block, and dont have to worry about lost metal filings
There is a drain pipe at the top of the head for oil (above the power steering pump). It travels down to the bottom of the block and had a small 90 degree rubber hose at the end of the pipe draining into the bottom of the block. You can cut that and put a T piece in there and direct the oil drain from the turbo into that T piece.
Got my braided oil lines.
Rough pricing of things:
exhaust manifold + Turbo $100
Walbro fuel pump $50
R34 GTT manual ECU $100
Turbosmart type 2 bov $20 lol
braided oil lines: $70
dump pipe $20
Fmic $50
Just need a front pipe and then going to do intercooler piping
cheers
i'm a 20 man, only recently acquired a 25 and thought that pipe was for coolant :laugh:
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
