I have just finished my turbo conversion in the uk and made 310 bhp and 275 lb/ft torque at 9psi would highly recomend this conversion to any one . Thanks for the idear and info 666DAN with out this forum and your info i would still be driving a 200ish bhp A/N and wanting more power . So thanks again ;) i have added a pic of what she look like .
Nice effort!!! Glad you gleaned some useful info from this thread :P It is worth doing and can be done very well as your numbers prove.
thanks guys just what i wanted to hear, i wont want to do any tuning or boosting, just want low boost to give some decent low down torque that the n/a sucks arse at.... so i should definately use the rb25det ecu, and what turbo will best suit the rb25de, the rb20 or rb25 turbo? and will i have to mod my loom at all for the turbo ecu
If you upgrade the injectors, fuel reg and fuel pump to GTSt spec, then the RB25DET ECU will be fine and be plug 'n' play. Bolt on an RB25DET turbo and run at stock actuator pressure and it should all work a treat.
Don't get a smaller turbo as it will spool *way* too early.
  • 3 weeks later...
It's not so much about the power numbers but the response with running an engine spec like this. Run with an intelligent tune there is no reason why it wouldn't/couldn't be reliable, possibly more economical, and with the sort of power that works well on the street.
That said, do we have any dyno sheets of any description?
Here's a graph of my RB25DET running 12psi to achieve 300hp. It's not overpowering, but very useful and responsive. The dip right at the top end is from pulling ignition to combat knock. I've considered that a well thought-out DE-spec engine with similar power numbers would be even nicer, response wise on the street. Perhaps water-meth is the key to making one detonation proof?
Edited by Dale FZ1
  • 1 month later...
how hard/difficult would it be to take out the rb25de from an r33 series 2 manual, and put in an rb25det engine and ecu?
what would be needed? would all the wiring match up? im guessing it wont....
any help would be great
This is the dyno sheet for my turboed RB25DE at 9psi
Edited by shawny
Hi Shawny,
Nice numbers. What mods do you have on your car? I am a new member here, from Canada, and have been having all sorts of troubles. If you can help me with stuff here, I would be grateful. I have an RB25DE with an R33 turbo on it, Trust FMIC, 370cc injectors, Turbosmart BOV and boost controller, with stock RB20DET ECU and Gredy E-Manage). Everything else is stock from my RB20DET days. Since they are new to Canada (how pathetic this is, lol), not many people know how to fix a Skyline, at least not as much as Australia or UK or Japan.
I am having troubles with idling (The TPS I am using is for the RB25DE, but my ECU is RB20DET, and the AAC valve is not working)....the cars sputters and backfires a lot, it hesitates under load and when I give gas. The power just doesnt seem to be there. Right now, after being dynoed once (260 rwhp), it has started sputtering between 2000-4000 rpm range, and the sudden bog/hesitation is still there. I dont know what is going on. What do you suggest? Also, please do share what youve done to your motor to get such impressive numbers. My motor also has the VCT on the intake side, but I dont know how to activate it with a switch.
Thanks,
Judas
Edited by Judasentinel666
  • 1 month later...
i have a neo st8 6 is it easy to fit a turbo on it i have been told
to Find a R33 with a turbo and fit it... (cheeper option)
and to fit a kit (if i can find one) will be around 13,000 bucks
but its hard to find one because the darn company went in 2 relaps and stop making turbos 4 the
neo st8 6
errr have u not read the start of the post dinobones? all u need is just a stock R34 turbo with FMIC/or SMIC with standard turbo computer and the oil lines tapped and water lines etc....then your all good to turbo and do something with the timing and thats it :P no need 13 000
CHeers
Chi
Munib, are u sure the car is not going into rich and retard, i had same sort of prob when i had a piggy backed na ecu, microtech solved my dramas but some sort of timing control is akll u might need
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
