sweet........
santa dropped by my place early this year :ninja:
most of my shiet have arrived.
big things such as exhaust/fmic ill get later on just before i fit the stuff up.
all i need now is ecu (tossing up between PFC or emanage), exhaust, fmic, & im done!!!!!!!!!
fuelpump, oil line & bleed valve/boost tee coming :laugh:
big thanks to all who supplied the parts to me;
justjap, rocket racing, niteworks, and users on sau.com & ns.com!
And you're staying first quarter next year you'll have it all done?? Yeah Right!!! You won't last, you'll have all this in by xmas won't ya :D
I'm still finalising a few things but I'm hoping to have up n running this month in time for Xmas ;) Earlier would be better, should there be any other issues afterwards xmas wouldn't be the best time to sort them out lol
Can someone confirm the difference between an R34 4 Door Catback Exhaust and a 2 Door? One workshop tells me that they will be able to supply a second hand jap catback and that it won't matter if it's a 2 door? Or would they just customise it a bit? Oh that's another thing I don't have yet either..a turbo timer. I guess these can be easily added later though.
yeah turbo timers are easy to find for $50 & under.
4dr & 2dr catbacks are the same.
SSS autos in syd confirmed this for me.
and i found out that its the same in R32/R33's as well.
lol narh it will definately be next year, im saving up for PFC now..
let me know how u go with it ndawg.
got my turbosmart ultra gate & screamer today! WOOT!
niiiice!!! Well that clears things up then... I've seen exhausts listed as being for 2 door and others for 4 door specifically, but yeah now that I've got a second confirmation that makes things a bit easier with buying an exhaust now.
Hey Vikz...you still selling your zorst? hehehe
What's the difference between the N/A and GTT radiator? Is there much difference? I would to an extent base a decision on that. If Nissan have used the same radiator then go with that initially.
After doing the conversion, see how it goes with the stock radiator, and then make a decision whether to invest in an aftermarket radiator.
I never had any issues with overheating, to be honest the only time I ever saw the needle move from its normal position was in 38 degree heat in stationary traffic on Smith St after sitting there for 30mins
hey now i hope no one just tells me to read the full 19 pages which i did but wondering....
has anyone got a full list of the parts needed to do a turbo conversion to an rb25de?
gonna do it to my series 2 GTS4 and will make a full topic about with pictures and everything just need the full list of parts first thanks!
Also in this thread are some pics of the top of my engine using stock R33 parts for plumbing, you could get a custom made 90 degree with BOV flange made, that would be prettier :( Ignore the dirt, it had been sitting at the recovery impound yard for a bit.
http://www.skylinesaustralia.com/forums/R3...um-t243157.html
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
