  • 9 months later...
  • 4 weeks later...
  • 2 years later...
Hello everyone
HELP
 i am currently converting my r34 GT rb25de NEO to now become turbo charged....now i have a couple of questions for you guys that i hope you can help me with.
#1 Is it possible to use a complete stock r33 turbo intake? or a fredyy/greddy? ( I HAVE BOTH)
#2 Can it be done using stock NA/DE engine Harness?
Lastly i Have  a Turbo R34 GTT Ecu to run it all.
THANKS! ADVICE IS URGENTLY NEEDED
  • 5 months later...
On 2/2/2004 at 8:38 PM, 666DAN said:
So you want to get more bang for your buck and whack a turbo on your skyline….well the following are things I’ve found out on this ever talked about path.
First thing…get yourself an N/A Skyline, if you’re reading this then you too have made this fatal mistake :)
The second thing you should do is get yourself some sort of engine management…one that can adjust airflow maps and injection maps…to a lesser extent timing.
I used the GReddy e-manage as my car is auto and I didn’t have a choice in the matter, even if it had been manual I still think I would have got it, due to the ease of installation and programming.
Other options available are getting the factory ECU…but I’m not sure if it would work as it would not have all the signals coming in that the stock turbo engine would put out.
Next step get the essential engine parts…you WILL need the following.
Turbo (of course) preferably with water an oil lines
Exhaust manifold
Dump-pipe & Front pipe
Fuel Pump (GTS-t one or better, plenty of high-flowing cheap ones out there, walbro etc)
Injectors (stock GTS-t ones or better)
Intercooler and piping (stock or custom)
Alloy cross-pipe with BOV (once again custom jobby will suffice)
All of the above can be the factory items or replacement parts for the turbo model, not a bad idea in the case of the intercooler…as with your 10:1 compression keeping things from going boom is a good idea :mad:
I used a series 1 R33 turbo, ceramic exhaust wheel jobby…you don’t really need anything more substantial as you can’t go too far past 7psi and the ceramic turbo should last indefinitely at this boost.
Almost all of these items went straight into my R34 with only the exhaust requiring an extra section welded in to make it fit.
The oil & water lines were modified and extended with stainless steel braided hose. The water supply was taken from the heater lines…the oil feed had to be taken from near the filter and the return is via a tap into the block..
Standard, the waste gate on the turbo will open at around 5psi..to get 7psi you’ll require either a bleed valve…or the factory solenoid powered by a constant 12v and put inline with the actuator hose on the turbo.
So now you’ve got everything bolted to your engine you need to get a complete dyno tune, where your ignition will most likely be retarded by about 5 degrees just to keep things safe. Once completed you now got a very different car from when you began…it’s actually got some decent power :D
Of course none of this would have been possible without Robin at *perFOURmance Motorsports*
The final tune on my car is Thursday, so I’ll have dyno charts and pictures available on Friday.
Anyone wanting specifics PM for more details.
So let’s see who’s next!
Dan
Could you run this setup through an auto easy enough? I have a 20e c34 would that work or would you recommend converting to Manual?
  • 1 month later...
  • 2 months later...
After reading through this entire post, which is great, I am still unclear how lower the compression ratio on a S2 REB25DE (R33). Is it just down to the pistons? If I replace the pistons with DET ones and probably rods as well, do I have the same CR as a standard DET?
I realise that I will not have the oil squirters, but maybe ceramic coating the pistons will help.
I think I have seen the valve springs might be a bit softer too.
Please fill in the gaps, if you have first hand experience with these and KNOW the answers. With the prices of RB25DETs in NZ right now I am considering rebuilding my DE, which I know, to DET spec, as close as possible.
You don't lower the compression is the answer.
but yeah the head cc is the same so comp is down to the piston dome
  • Like 1
Rb25de from 25det main difference is CR,if you change pistons,you will have det,except no oil squiters,head is 100%same,rods also the same,did the same for my DE,but i put det pistobs with rb26 rods,cause they are stronger,i am pushing 500hp on my setup,with Tonei cams,N1 oil pump,and be sure to install crank collar if you will dismantle your engine.I pushed 350hp with 1bar boost with stock DE,untill 2nd cylinder ringland failed,so its up to you,if you go over that,you need upgrades
Very helpful. Thank you Rolandas.
Another question: Are you running without the squirters? You have not installed them yourself as other have? That is pretty impressive numbers.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
