just wondering, what did you have installed which alloud your R34 to like positive boost.. my car stalls when i hit more than 0.00
thinking its the ecu, just wondering what i need to 'fix' this issue :rofl:
Yeah you need to have some sort of ECU change most aftermarket ones will do, the e-manage ultimate is more than capable of sorting your issues, you can even buy an optional harness that allows you to retune the car for exact turbo pressures.
Man, This thread was heapz good....
all waiting for dyno results then car goes missing...
All i can say is POOH JABBA!
Tell me about it....it's like an unfullfilled dream, I'll never know what it was pushing :rofl:
Tell me about it....it's like an unfullfilled dream, I'll never know what it was pushing :)
i had problems when tuning my greddy emanage.. could you sent me your emanage settings? just for my reference.. i had install the pressure sensor and it didn't show up... and keep on blinking when not connected to pc. and stalls whenever i release the throttle when slowing down..
I'll have to look around for my e-manage files, after the car was stolen I didn't see the need to keep them.
When you install the pressure sensor you have to create a new map file, with the provision to record map pressure (in the setup menu) otherwise it won't recognize it.
Hey, you stated that the conversion may cost around $3000.
In my case, ( I own a R33 gts ) would it be simpler to just get an engine swap or front cut? What would be left for me to change besides the ecu? If i opted for one of the two?
Okay, mid last year i did completed my NA to turbo conversion.
cost me over 6g in total to do it..
here are the dyno sheets.
this is from when she was N/A, and only had cat back exhaust on it.
http://www.members.westnet.com.au/mirks/MIRKZ/mirkzdyno.jpg
this is when all work was complete, running high compression still but with turbo.
http://www.members.westnet.com.au/mirks/MIRKZ/mirkzdyno2.jpg
in the 2nd graph it shows black lines an a blue one, the black was a previous dyno that was done that got 273 at the rears but had a dodgy coil pack, The blue is after the coil was replaced.
If you look on the dyno it shows he running 9psi. I've almost done mine got all the parts just looking for a tuner in W.A gonna ring around tomorrow
excuse my ignorance where exactly do you look on the dyno reading for the psi amount being run?
it would sound similar, but slightly different due to compression.
every car sounds slightly different with just the minor mods..
6g would be for half cut + putting engine in.
3g would be ecu + 2nd hand parts to turbo it. (plus tuning of course)
  • 4 weeks later...
Is the head on the rb20de the same as the rb20det,I have to do the turbo conversion on my car to get it complied & I can get the head & turbo etc for nothing,I had heard that the difference in compression was in combustion chamber is this right or not.
  • 3 months later...
  • 4 months later...
Does any one know if the ecu wiring plugs for a N/A skyline and a turbo skyline are the same, im just helping out a mate with a N/a skyline with all standard turbo bits (fuel pump, injectors etc) as i have a standard ecu for a r33 gtst s1.
lucas
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
