yeah its my new drift car.
its got 10:1 CR
no decompression.
when it f**ks out a piston, ill slap a 3litre bottom end in with some cheap forged pistons.
it should last for a while, its got good oil pressure and its got mega amounts of fuel going in.
The highest I ran was around 8psi, with some decent cams and a highflow turbo I think I could have pushed it a bit further. Also another thing which will be a benefit is getting some colder spark plugs...7 range.
thanks again dan...just wondering would i b able to run psi of boost more safely with forged pistons n 660cc injectors n those 7 range spark plugs...and would it also kick in around that same sorta rev range?
thank you sooo much.
If you're going to lower the compression when you put the forged pistons in, then yes you can run more boost. Guessing at the size injectors you want to put in you'll want to be chasing >18psi anyway to make use of all the extra fuel
ok sweet all ill need is forged pistons, 660cc injectors n those spark plugs n i can run that amount of boost, thats awesome...will the boost still kick in early? wat injectors would u recommend just to be able to run to about 15-16 psi safely?
Well it's more of a case of compression, there is no way that you can expect anything more than 12psi even that's with awesome cams and a great tune. Most people will be running ~8psi on 10:1 comp.
Forged pistons will drop the compression to whatever you want, but it will turn the engine effectively into a normal 25DET really, so the boost will kick in as it normally would with no advantage of high compression.
If you want to keep the high compression, take advantage of it with one of Slides highflows, run 8psi on normal 370cc injectors. It'll have awesome low-down torque and fairly respectable power.
ive got a problem with controlling boost, its running up to around 0.8 bar which is more that i want. there is a bleed valve on the wastegate line but its fully closed, i think it may be still causing a boost increase so im gonna bin it.
boost is instantaneous. i still havent hooked up the NVCS so it falls over pretty bad, and the plugs are gapped at 1.1 so it breaks down slightly, but once i overcome these probs, it will be great.
the only hole you have to drill is for the sump return fitting.
the RB25de doesnt have a oil drain from the turbine so one must be welded into the sump (unless you wanna machine the block - FLAG)
otherwise it all bolts on NO WORRIES MATE
just bolt it all on man... its a no brainer.
if anyone is planning to do this, i have the stock R33 intercooler and piping for sale atm, for $80 ono. just pm me, its all in very good condition btw.
Don't be fooled gents. its not only the compression factor, but the piston itself, the N/a pistons are not Hyperputectic. therefore, even with low boost pressures, after a while you will melt a piston.
By all means, do this upgrade! turbo is 100% better effecient power, than most other mods. But do plan to change your pistons over in the near future.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
