Im gonna run 10, thats my absolute limit. Im running 6.5 atm, car spools nicely. Its weird having it on boost at around 2200rpm, then thinking, gee this is pulling hard, then that weird ass top end power comes on and your off twice as hard. Great fun
Yeah I had the same with my car, it was bizzare...the top-end was impressive
  • 5 weeks later...
For anyone interested in doing this conversion, I made 210rwkw and 475nm on Dr drifts dyno today @ 9psi with stock injectors, stock ecu & stock R31 fuel pump, cooler and high flow t3/4
Edited by juddieR31
666Dan, how much boost was the turbo making from off idle?
I've worked on a few RB25DE's which have had RB20 turbos fitted to them and they were practically making boost when idling. Massive torque down low but runs out of top end very quick... One of those cars now runs a fairly insane turbo/setup (still high C/R for response), makes about 300 rwkw or so, that was done nearly two years ago and its still going, really needs good tuning to keep them together....
hey man, i wanna turbo my r33 rb25de what computer do i run, some ppl say rb20det and some say rb25det, some say the rb20det wont work with the vvt etc and the rb25det is too hard to tune, im confused i can get all rb20det parts real cheap but dont wanna do it unles i know what ecu will plug in and work, can i get away with just a std turbo ecu and tuning and no link or safc etc as im on a tight budget, only want to run stock std boost...
cheers guys
my sugestion is if your on a tight budget then wait until you got the money to do it properly, you never know what might go wrong and end up costing you shit loads to rectify, as for ecu, i would not sugest any standard ecu as it will not be safe to drive, possibly a standard TURBO ecu with a piggy back, but aftermarket is always best, as for r32 ecu it will work but i think something has to be done to it to make it work ie some pins have to change or somethingh and it will need to be re-mapped and you will need an aftermarket cam controller, dr. drift suply and fit r32 re-mapped ecu's with cam controler for around the $1300 including dyno time, or you could spend the extra 500ish for an aftermarket unit tuned,
As these guys have said, if you're not after full tunability, the stock ECU is fine..generaly the tune on it is quite well suited to the higher compression. Stick and SAFC/emanage on it if you want to adjust a bit more.
I have just finished my turbo conversion in the uk and made 310 bhp and 275 lb/ft torque at 9psi would highly recomend this conversion to any one . Thanks for the idear and info 666DAN with out this forum and your info i would still be driving a 200ish bhp A/N and wanting more power . So thanks again :O i have added a pic of what she look like .
hey mate wat mods do u have in ur car to make that sorta power?
Hi mate i have a 100mm front mount intercooler and hard pipe kit , GReady E01 with Emanage , FSE fuel pressure reg and fuel pump , Gready turbo elbow down pipe cat pipe and 2" N/A nismo exhaust , Apexi oil cooler , HKS and Green induction kit with cold air feed , engine circle earth with voltage stabeliser , uprated blow off valve with about 4 hours on the dyno and in the process of fitting 25 shot of nos and intercooler sprayer which should give about 40bhp on top of the 310
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
