Hey,, does anyone know what cooler this is for??
I have a sedan A/T. I'm pretty sure its not a transmission cooler since it should be with the radiator?
So, would this be an Oil cooler?
In images 1/2 it shows the piping going to something that looks like an oil filter ??
thanks...
https://www.sau.com.au/forums/topic/334078-what-cooler-is-this/
Yeah deff the trans cooler my gt-8 looks identical.
On the gt-8 it runs into the radiator and then into that oil filter thing then the air to air cooler. Thats getting pretty serious imo.
Is yours a gt-8 or the normal auto?
Its suprises me if the auto trans has the same setup. I wouldnt of thought it would need both.
yeh i have gt-8.. mmm
so that means i dont need to purchase a trans cooler?
because my new rad doesnt come with one.....
You should have 2 coolers - one in the bottom of the radiator and the one pictured above.
The cooler in the radiator works to try to keep the trans oil at a constant temp, ie heats it up in the winter/when cold and cools it in the summer.
Obviously Nissan decided that the GT8 requires a second trans cooler to preserve the transmission.
If your new radiator doesn't come with one, take it to a radiator place that will put the stock "cooler" in the bottom of the new radiator.
Whilst I don't have the CVT (My Stagea has the RE5RO5A - same as 5-speed V35's - but AWD, obviously), when I replaced my radiator I found that in winter I needed the in-tank cooler (noticeable difference in shifts due to the trans ECU's oil temp settings), so had the stock one ripped out and added to my custom radiator.
Edited by iamhe77
You should either get the correct radiator with the oil cooler...... or upgrade your current oil cooler when you replace with that radiator your looking at and drive slowly until everythings warmed up..... probably not the best.
Replacing with the correct radiator is the best option as i have seen a chart that shows the best operating temps for the traction oil and it actually likes being reasonably warm (traction effect goes up with increase in temp within its operating range).
If you go with a bigger air to air i would use a thermostat.... assuming the black round thing is an oil filter and not a thermostat.
You need to find that graph im talking about that will let you know what temp thermostat you would need... cant remember where i found that now.
If you do pull it all apart check that black round thing is a filter as im keen to know myself?
thanks for the info...
so basically keep the stock cooler and rip out the cooler thats in my current radiator... ?? or.. get another cooler??
my radiator is leaking, thats why i'm changing it out.. called up a few wreckers around Sydney and the price for a radiator was around 400... so i felt better off just buying a new one...
austingtir: keen on that graph if you ever find it again...
Edited by moomoolulu
Yep, keep the stock cooler and make sure that your new radiator has a transmission "cooler" in it.
If that means you need to get the original OEM one taken out of the busted radiator and put into the new one, so be it.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
