We just fitted a Blitz NUR spec V 3 inch zorst to my cousins R34 GTT and wanted to mention how it went and some peliminary results .
First of all a very nice looking zorst with excellent welds , as little bends as possible . To those of you not familiar with this model at looks similiar to a N1 system but with a much straighter tail pipe . Speaking of the tail pipe its 4 inch all the way through! .
It was fitted together with a matching front pipe but the std cat is left for the moment . They car hasnt been dynoes as yet (more mods to come) but it definatly goes better especially at the top of the rev range but its freekin LOUD , i mean this way to loud for steet use but lucky it comes with an adjustable silencer that really takes the booming out of the sound and leaves it with that nice twin cam RB note.
As soon as a photo is taken ill post them up !
ps it was also sourced at autobahn in epping ask for Daniel as he specializes in all the jap stuff.
https://www.sau.com.au/forums/topic/33410-blitz-nur-spec-v-zorst-fitted/
of course its loud its a 4" almost straight pipe :)
it would be similar to the 3.5" straight pipe exhaust that was on my gfs soarer... that thing was like 100db at 2000rpm ;)
sounded awesome coming down the streets...
lmao oh ok that makes sense... 3" then :)
man my gfs is actually 3.5 piping from cat to the tip :cheers: that thing was LOUD... even with the bloody extra muffler we had welded in and the silencer :)
inark, he means the tip is 4inches.
i used to have this on my car but sold it cause drew too much attention and gave me a headache after 5mins, even with the window up!
Yeah thats what i meant ! The pipe is 3 inch however the rear muffler and tip extend to 4 inch .
We fitted the restrictor but it still felt like it went quite good .
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
