Hey
I just got a Power FC Pro in my R32 GTR, I was wondering what levels or knock are normal and what is bad.
Like whats the max level it can go to but still be ok??
I cant seem to find any info
Im running my power fc pro on bass map atm due to waiting for $$ for tune, so will my knock levels go down after tune??
If anyone can help me with this info
Thanks
M3M3NTO
https://www.sau.com.au/forums/topic/33417-knock-levelsreadings/
This is a general FYI that should be available in a search.
The FC has a synthetic knock sensor. It is only a guide and really only as accurate as the sensors themselves.
A good reason is around 10-15 or less on load, a hot engine, all boost levels.
Older engines do anywhere from 30-40-50.
Make it what you will of motors in the 60/70+ range.
Again FYI.
My motor did a 7-8-9 before it blew.
It still does a 7-8-9 after the rebuild.
ie. I phuqqed a completely good motor but I still have a completely good motor after the new pistons etc.
T.
Your Knock levels will go down after a tune. If your car is knocking under load it could be leaning of a little. Your tuner will add some fuel at that point in the map, you can use the map tracer function your self to find exactly where in the map your car is knocking. The tuner could also retard the timing a little to reduce the knock.
Like TonyGTST said: Your knock sensor on the pfc is only really usfull when the car is idling, its main function is only to tell you if something is really wrong when first installing the pfc.
ps, when driving if you see the engine warning light come on back off staight away or you risk a blow out....
hope that helps.
We dont get Synergy in Canberra... it is Mobils high octane PULP, and its damn good (filled up my car in Sydney with it before heading back to Canberra). My car never knocks whilst driving above 3, its 99% of the time always on 1. Ive just had the engine rebuilt and its running pretty rich, which might have something to do with it.
i've hit 150 on my powerfc.
optimax is the worst fuel. ultimate is the best. i notice significant knock level differences when using the different fuels. synergy sits somewhere in between, probably closer to optimax.
i've never audibly heard it detonate.
Not this argument again. I would say that if you hit 150 knock on your PowerFC, it says more about your car than the fuel you used. I have never had a problem with Optimax. Although I only prefer it because the stations with it are more plentiful and I know where to find it cheapest. Only about 1 in 5 BP stations carry Ultimate in Sydney.
Once every BP starts carrying Ultimate I may change my preference but until then, or I strike a problem with Optimax, I will be happy pulling into any cheapass Shell I see and know that I can get 98RON fuel there.
In my area a few Mobils also carry cheap fuel until Wednesday or sometimes Thursday. If I'm out of fuel on one of those days and I see a cheap Mobil, I have no problems filling up with Synergy at 10cpl less than everyone else.
I use shell, and the max knock I got was 25 on standard boost and 63 at 1 bar, my power fc pro is untunned and running bass map till I get the $$ and some more mods
Im guessing once tuned my knock level will go down alot?
i have to admit that i cannot quantify what i claim with any hard evidence - it is purely observation and i say it with the utmost unbiased opinion.
i definately see no performance difference between the 3 fuels but i can firmly say that on higher loads when fueled with BP Ultimate my knock sensor reading will remain *relatively lower* compared to the other brands.
yes it's obvious the tune is poor towards the top end of the rev range, but my argument is the powerfc tune remains constant whilst my brand of fuel is changing (and i fill up each time with a full tank) and the trend is consistent.
yes the weather and time of day is definately a variable in this equation but my argument to that is i've had too many tanks of fuels in varying weather conditions to justify this reasoning.
id definately be interested in hearing what you have to say about the car over the fuel?
cheers,
    • And if it still spikes, just for now, turn off VCT completely by disabling it OR simply unplug the solenoid. Just to rule out excessive exhaust pressure. I recall a video from Motive DVD about a decade ago, where Hawkins original single Garrett GTX3582 or so turbo had boost control issues sub 1.4bar of boost as well.   Food for thought? Is there anyway you can peg the WG completely open and/or dodgily not plumb it back into your exhaust system for testing purposes?
    • I will endeavour to give it a crack sooner or later. I have the wastegate apart at the moment so I'll replace it with a smaller spring just to see what it does and if I have to go back then so be it.   If it spikes to 23 but can then be controlled back to 20, then the gate must not be 100% open... So if it's not 100% open then why can't it drop the boost even further than 20psi (I understand it's not linear). What a headache this whole thing is.
    • Either the WG is reaching full opening, or it is not. The "it is not" case could only occur if there was not enough time available to swing the valve fully open during that boost event. I would consider that to be unlikely, as this is a commercial product that is in use elsewhere, so it really should work. But in your case, because there is definitely SOMETHING wrong, it should not be assumed that things like that are working as they should. You should put a video camera where it can see the actuator (if at all possible) during a run to see how far it is moving.
    • I think you're mostly on the ball there. With the straight gate, I suspect the weight of the spring will determine how quickly the gate can close, when not run with active pressure drive on both sides of the diaphragm. Otherwise, with drive on both sides of the diaphragm, you could almost go without a spring at all, only needing one to make sure that the thing was actually closed while completely off boost and not having pressure available to drive it closed. Butterfly valves have mostly symmetric loading when there is flow going through them, meaning that the gas hitting the upstream part of the blade is balanced by the gas hitting the downstream part of the blade, which means you don't need actuator torque to overcome any non-symmetric flow induced loads. But the gas flow does impart a purely normal load against the shaft, which transfers into the bush/bearing at each end of the shaft and does increase the torque required to make the shaft turn. Only a little, but it is there. I have no feeling for the amount of force involved in a WG application, but it certainly could make an argument for a decent spring weight being required. But all of this is just peripheral to the actual problem here.
    • The answer to this would be I followed the documentation from Turbosmart which said each spring pressure could achieve a maximum of 5x it's rated pressure so the included smallest spring being the 6psi had a range up to 30psi. I went with the 12 because I figured it'd likely hover around 15psi as a base pressure however I was obviously wrong.    I have a log here that I'll dig out that is purely wastegate and no Mac valve controlling anything.   If it can't hold anywhere near 12psi, does that mean the straight gate is virtually wide open during a run? Or am I thinking about this all wrong.   I could Tee Piece into the cooler pipe pre intercooler where the wastegate gets its feed, and send that to the ecu and see how that reads, I just don't have a spare pressure sensor currently that's all.
