hi guys,
just a question:
i was recently received a Excessive Noise Statement and did the required noise test.
so i went to Daalder Zorst in boxhill. not knowing much abt this noise test, he set up the mic etc etc and revved to 4800rpm. then said that my zorst was 10db over.
*ouch
anways, went back to the import dealer and one of the mechanics said that this particular guy at daalder was dodgey and makes a job out of these inspections.
the mechanic told me to goto a shop in st albans. i did that the following day and the tester said that 4800rpm was utter bull. this guy only tested my noise lever at 3200.
his explanation was that all cars that are imported and consequently have no engine numbers are tested at 3000 or there abouts.
any comments?
btw, i'm new to this forum
as you can see, this is in the wrong section...could an admin kindly place this in the correct section. excuse my retardedness
https://www.sau.com.au/forums/topic/33418-epa-noise-test/
Yeah.. you always have got to be a bit cautious.. because the exhaust shop has something to sell you, but they're not always going to shark you. Plenty of jap. exhausts *are* way loud and don't meet Australian standards.
Anyhow noods, it don't really matter who you take it to and what they measure it at, as long as they're an approved EPA noise tester and can write off your notice then thats all that really matters..
https://www.sau.com.au/forums/topic/33418-epa-noise-test/#findComment-670784
I took my car to Daalder in Box Hill.. and they were great..
they also did the test at 4800rpm
Im guessing they know what they are doing.. and the exhaust shop in st albans dont know what they are talking about..
I also have had nothing but good experiences with Daalder!!
https://www.sau.com.au/forums/topic/33418-epa-noise-test/#findComment-671268
hey guys, i need to go to test mine too, so which one better? st albans? box hill dallder?
i already got an aftermarket with resonator and muffler? what else "special resonator" they can add?? i'm hoping mine is around 89db though...
https://www.sau.com.au/forums/topic/33418-epa-noise-test/#findComment-674594
I had an EPA on my bike at the start of last year. Ended up taking it to "a" St Albans tester (without naming names) and it was way over before we even got half way to the testing RPM. For a small fee (including the test) all i had to do was get some stock exhaust pipe numbers from a bike shop for him to say he saw it on the bike. The stock numbers went on the certificate and i rode off with a "quiet" bike. If i get done again, "i swapped my exhaust system back after the test".
I guess he only did it because he doesn't sell motorbike exhausts. Some guys can be pretty cool.
https://www.sau.com.au/forums/topic/33418-epa-noise-test/#findComment-675855
Obviously higher than our 90db... maybe like 93 or 95
But there has been a new Jasma standard released sometime last year maybe, and best bet is to get the latest model exh from jpn that conforms to the new standard, as it will definitely be quieter than exhausts models made 3-4 yrs ago, and new models could under 90db (perhaps... ?)
https://www.sau.com.au/forums/topic/33418-epa-noise-test/#findComment-678888
Guest
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
