Excellent advise here! Never ride a big bike again and have your memory erased so cant remember what it was like. Cheapest way out of this.
I drove a 2L diesel van for 6 months whilst my car was off the road, peak power at 2500rpm and a redline of about 3200, that and it was about 20m off the ground, after that even my mums 1.5L civic felt fast!
  • Replies 107
I do get that feeling also, I drive a truck for a living... 62tonne B-Double not exactly the fastest accelerating machine!
GTR feels like a Go-Kart after 12hrs driving.
I spend a few hours a day trolling threads and reading different results from peoples setups.
I'm set on getting to the 400kw mark when the time for upgrade comes so instead of have a toy in garage, I have a "Silly Toy"
Edited by Turbo Dave
  • 1 month later...
As much as I'd like to deny it, I am good friends with Ash. He's more misunderstood than a real tossbag :(
I did run an 11.2@127MPH with 347awkw on a stock 2.6L bottom end and 2860-5 with 19psi and super safe tune as dynoed at RE Customs. Drove in with 1/2 tank of fuel, dropped tyre pressures, ran back to back 11.2 and 11.3 along with 3-4 other runs which weren't as good, drove out to servo, pumped up tyres, filled petrol, drove home. Easy.
400rwkw on street tyres will net a 10 sec pass as long as you can launch properly. Everything in a GTR is at launch. After that, it's a pretty simple game.
I wouldn't be surprised if Ash does run a 10 with 400awkw. Even he couldn't fark up something this easy. LOL!
Well given he is a good friend of mine and we were actually discussing it yesterday, I'd be inclinded to believe my version. :D
You aren't the only one, plenty of cars out there are using factory dumps and making 330-380rwkw.
If you are so dead certain the car doesn't have anywhere near the power spend $80 and put it on another dyno and see, would be the first thing i'd do.
(i've gone from racepace to dr.drft, varience of a whopping 10rwkw)
Anyway, proof will be in the pudding - I'll remember this thread for a time when i run a 10 with factory dumps and -5's!
Till then :(
As much as I'd like to deny it, I am good friends with Ash. He's more misunderstood than a real tossbag :D
This is highly relevant to my interests, do you mind sharing your set up or specs ? that's pretty farken quick :thumbsup:
It was all pretty stock standard built engine mods I guess.
Intake & Exhaust
- Trust Drag 4" front mount intercooler (Twin entry)
- Custom 4" dump pipe from Turbo
- Apexi GT Spec 3.5" exhaust from dump pipe
- External (Screamer) 3.5" Seperate pipe on the Wastegate
Engine
Top End
- RB26DETT i6 24valve twin cam head
- Rod Smith Custom Group A cams
- Tomei Valve springs
- HKS 1.2mm metal head gasket
- HKS adjustable cam gears
Bottom End
- Wiesco Forged Pistons
- Nizmo Group A rods
- Balanced & machined crank
- HKS Oil pump
- GTR water pump
- ACL bearings
Turbo, ECU & Fuel
- Twin 2860-5
- Stock GTR piping
- Autronic SMC ECU modified for a GTR
- Autronic CDI
- Trust Profec B Boost Controller
- Aftermarket Jap 880cc twin feed Injectors.
- 2x Bosch 979 Fuel Pumps fed by stock GTR intank fuel pump.
- Custom built Racepace Motorsport oil catch can
- HKS ETC with drag apaptor
Drivetrain
- OS Giken Cross Mission gearset in Nissan factory housing with billet sandwhich plate
- Custom Built Jim Berry Clutch within Ogura Triple Plate Housing (4400lb Clamping Pressure)
Suspension & Brakes
- Tien RA fully adjustable coilovers
- 4 Piston Brembo Calipers front with EBC Greenstuff pads
- 2 Piston Brembo Calipers rear with EBC Greenstuff pads
Appearance
- 18x10.5 Bronze Weds SA90 forged rims
- 265/35/18
- 265/35/18
- Nismo style rear spats
- Tinted Windows
Interior
- Sparco race pedals
- Momo Race Steering Wheel
- Blitz 340 km/h dash
- Nismo center gauges
- Blitz DC Turbo Timer and boost gauge
Sound System
- Alpine head unit
- Alpine 12 disc stacker in boot
- Alpine front splits
- Alpine rear speakers
- 2x Alpine V12 amps
Intake & Exhaust
Engine
Top End
Bottom End
- HKS Oil pump
- GTR water pump
- ACL bearings
Turbo, ECU & Fuel
- Twin 2860-5
- Stock GTR piping
- Autronic CDI
Drivetrain
Suspension & Brakes
Appearance
- 265/35/18
- 265/35/18
- Tinted Windows
Interior
Sound System
- Alpine head unit
Awesome,
Cheers mate.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
