Hey i have an R32 gtst that im wrecking. any interior, exterior panels and engine parts. are available at the moment so if your interested call or txt me on 0417090965 to make an offer. Engine only has 105xxx kms. Which is very low for a 32.
- GTR side skirts and rear pods which i got off a gtr so they are plastic NOT fibreglass. $300ono.
- adjustable coilovers/ lowered suspension $500ono
- manual gearbox $500ono
- front and back seats $100 for the lot
- doors $100 ono
- door trims $30
- dash $60
- turbo timer $15
- front mount intercooler piping $100ono
- headlights $100ono
- front 1/4 panels $75ea
- scuff plates $30 for pair
- centre console $50ono
- seatbelts $20ea
- skyline floormats $30 for the set
- 3 inch catback canon muffler exhaust. (Mandrel bent) $125ono
- turbo $150ono
- manifold $200ono
- brake calipers $50ea
- ect..................i think you get the idea.
here are some photos. I have not pulled the engine appart but will do on request for parts.
if there is absolutly anything you can think of send me a txt. or even if you want to come round and pull something off the car and make an offer txt me to arrange. Car is located in Padbury.
Ey u got the rubber door trims? and also r u selling the rims?
yer mate rubber door trims for $20+postage.
the rims are different sizes so that the car sits on a tilt. I think the rears are 17;s or 18's and the fronts are 16's. $350+postage for the set.
wots your postcode and i will let you know postage.
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
