Hi all,
Installing boost controller and PFC and getting a tune in the next few weeks. I've been told any 'in-car' engine management is illegal so I was wondering if any of the WA lads have had trouble with this in the past and where you may of mounted yours on your R34 to best conceal it.
I have a profec b spec 2 if this affects anything and I suspect that once tuned I wont be touching it much (low boost at 5 high at maybe 12 on stock turbo).
I suppose normal place is under the steering wheel or either side of it but this is pretty noticeable from what I've seen, maybe could get away with saying its a turbo timer =/
Cheers in advance, any pics will help greatly guys.
ta,
Steve
https://www.sau.com.au/forums/topic/334266-r34-boost-controller/
Hi all,
ta,
Steve
Turbo timers are technically illegal as well. Usually get away with them if they dont f**k with the alarm/immob. though.
For boost controller....well I've wedged in front of the ash tray, the R34s are a bit different though. If you have a pocket under your CD player, go in there (like this turbo timer):
But if you're rarely going to touch it, put it in the glovebox maybe ?
Edited by Nic_A31
Hey man,
I have managed to pass the pits with both a turbo timer and boost controller in plain sight. Police didn't even bring it up when I was pulled over (I was stickered for a different reason)
So stealth is cool for looks, but I wouldn't stress about it
Blitz boost controller is on top of my steering column, so I can see/change boost levels (gauges are fkn homo IMO)
PFC hand controller is in the passenger glove-box.
Turbo timer is built into the alarm system.
Had no problems through the pits.
Yeh, thanks Brad that would be awesome.. although to improve the ability to read it easily I was thinking on top of the drivers side-view mirror with a bit of double-sided tape then I can wind down the window and reach out and set it as I require.
And Bubba.. you should smother paint over some bewbz and use it as an advertisement for your business, i'd definitely come play if I believed there would be paint-smeared juggaloons..
Should have come to the tournament at the Red Bull Air Race.. we had the several hundred bikini clad women heading to the photo shoot at the bell tower wander past.. needless to say everyone dropped their guns and their jaws!@
We needed them agin on the weekend and then I would have been in heaven.. paintball cars AND boobs!!
Edited by bubba
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
