Hey,
I've got a pink R33 but the paint on it is starting to chip off around the windows... The shop that sprayed it is no longer open, lucky me! :wacko:
I'm not happy with the job that's done on it, I'm thinking maybe another coat of pink on top, maybe a bit darker.. It's been sprayed smooth so no runs or anything so it wouldn't have to be fully rubbed back,I don't think??
Just wanting to know if anybody knows of any places to check out cos as you can tell I made the wrong choice the first time. I just want a cheap job, if there is such a thing... I'm from Newcastle but can drive to Sydney area for it... Any help would be much appreciated, Thanks xx
https://www.sau.com.au/forums/topic/334284-respray-advise-needed/
Yeah if you're not happy with the first time.. Then cheap is not what you want.. An cheap job will either look shit or won't last.. And you'll be in the same place again, do it once and get it right the first time instead of cheap shit jobs and having to re fork out $$$ to keep coating..
If you can show me the full photo of your avatar pic.. then maybe we can help more???
If it's just small areas that need fixing up.. just go talk to a panel beater.. They can sort little stuff out fairly easy.. But there is no such thing as a cheap job with good quality.. It's gonna cost what it costs.. I'd check their other work out before going ahead.. And get several quotes..
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
