  • 3 weeks later...
  • 1 month later...
20 is out, 26 is upside with sump off and its all ready at the enigineer's
-Modify Sump
-n1 oil pump
-New water pump
-New water pipes
-new gaskets throughout inc inlet, exhaust, rocker covers, front crank seal, rear main etc
-New engine mounts (old ones broke on way out)
-Need either another z32 and a chip so stock ecu runs it ok, or a pair of stock GTR air flow meters till i go aftermarket ECU
-Paint inlet and covers
-New catch can
-Front Pipe
-Modify Cooler Piping
-install twin plate
-New filters
-install motor
-Finish wiring
think thats a pretty small list considering!
  • 4 weeks later...
OK finially some progress and some new pictures, Have sorted out the wiring. and all the plumbing on the 26. god there is alot you dont need!
Aircon compressor removed, rb26 power steering pump removed and the rb20 bolted into place. (conveniently fits using the standard mounting location of the air conditioning compressor)
Front pipe has turned up, still waiting on AFM's and hks hard intake kit. But the thing really slowing me down is the VRS kit, will seriously hurt somebody if this shit doesnt turn up soon! As soon as it gets here the motor will be redy to have clutch bolted on and motor dropped into place.
All the engine covers have been nicely painted aswell. Here is some pics, also one of my new workbench :)
(actually just reallised i didnt take one of the actuall work bench so i will get onto that in the next few days )
Whole front of motor is finished
Cam seals
N1 oil pump
Water pump
crank seal
new idler bearing
new tensioner and spring
Gates timing belt
hmm think thats the whole front? Was starting to get super angry as i realised i got sent 3 crank seals instead of one crank and two cam seals... turns out cam seals are same part number as crank seals in 32 gtr's haha :)
Still waiting on vrs, and waiting for my standard manifolds and dumps to get painted in that black heat proof stuff. Should tidy it up a bit.
Then only thing left is rear main seal and bolt clutch/flywheel up and drop it in
Wiring is allready finished. Then just mod front pipe to fit my existing 3" cat back system and two cooler pipes and bam back on the road :)
Also found out i got a nice surprise turbo wise with my front cut, .60 - .64 turbos, There either N1 or Nismo Group A turbos. Pretty happy bout that
  • 1 month later...
Car is finially finished and running, honestly cant stress enough if you want something done right do it your f**king self. only outsourced one part of the build and it put me behind 3 weeks and cost me more money
but 10psi for a week or so, a second oil and filter change. some dyno time to check afrs after that and happy days.
And some new semi slicks tomorrow morning! happy days, words cannot express how it felt to drive it out of the garage for the first time in 4 months!
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
