what's the deal with the S-tec R35 that costs nearly 3 times the price of a base model?
I believe S-Tec is a car prepared for a privateer racing series in Japan.
Also, looks like the price of the base car has jumped significantly.
I like the fact that the wheels are lighter but I am not sure that I like the look of them as much. I don't like the LEDs. They should have incorporated the LEDs into the headlight IMHO. Perhaps something like BMW's 'Angel eyes'?
'Angel eyes' are even more played-out and tryhard than LEDs
yes but angel eyes, are for the most part, only seen on BMWs
every ricer with an ebay account or a local autobarn is putting led strips on their cars these days
those people who use them during the day bug the sh!t out of me......"alright relax mate, we get it, you optioned your A4 with xenons, you're cool"
im not too fussed with these minor changes, exterior tweaks look like changes for the sake of it, especially the wheel design which looks a bit too soft - the Rays on the 370 look way more aggressive with their concavity
the only option ive ever lusted after is the white seats out of the JDM models
oh, and ill grab 5 of those new hvac knobs from the dealer next year thanks :(
Edited by domino_z
Meh...not a fan of the styling mods to be honest. LED driving light are just gay as.
agreed...
though I don't have a problem with actual BMW angel eyes, sure it's pure wank factor but it was something different, can't hate on 'em personally :ermm: just the people that buy kits & put them in
Audi's LED strip was just a limp-wristed response to get on the bandwagon & tossers that put them on their commo/falc/civic/lancer make me wince when I see them
I like the wheels, probably need to see it in real life. I was never much a fan of the general styling of the R35 until I got to see one in the flesh, same goes for the 370z
oh, and ill grab 5 of those new hvac knobs from the dealer next year thanks :ermm:
AFAIK The point of the LED strips are as "DRLs" (Daytime running lights) the idea being that it makes you more visible than using your headlights (Proven safety step) while not having the adverse effects (globe life, power sap, glare etc) therefore they would be something you would want to have on during the day
LEDs (Light emitting Diodes) are also very different to Xenons, which are a really bright, clear globe for your headlights, as for the Angel eyes only being on BMWs, type "Angel Eyes" into Ebay and see what you cannot get them for....
Have noticed though that Xenon driving lights etc are getting the ring around the outside of them a lot now as well
Stand to be corrected
yep i know
but as per my post, it's only the Audi's with xenons (standard spec or optioned) that have the leds
if you have halogen headlights, Audi replace the leds with a few 5w halogen globes instead
btw i put angel eyes on my E46, not in a ricer ebay blue colour though, oem yellow
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
