Rb20det Bits.
RB20DET Coilpack Loom - good condition, no misfires. - $50
RB20DET Ignitor Module - $50
RB20DET Injector Resistor Pack - $10
RB20DET Turbo + Exhaust Manifold - I never had a boost controller so was running on stock boost. - $100
RB20DET ECCS Inlet Manifold - complete with injectors, fuel rail, throttle body etc. - $100
PM/SMS. 0438858813.
RB Flywheel $50
Gearbox Sandwich Plate $10
R33 Speedo Sender $50
Clutch Throwout Bearing (NEW) $35
RB20DET Gearbox Yoke $50
SECO Pressure Plate $50 (Jim Berry rebuilds these for his clutches)
R32 Starter Motor $20
RB20 Dump $20
NISMO Clutch, pressure plate is machined, $50
RB20 Ignitor Module $50
RB20 Crossover Pipe, with BPV attached $50
RB20 Turbo + Exhaust Manifold $100
Pictures can be found here: http://www.skylinesaustralia.com/forums/in...t&p=5417501
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
