  • 3 months later...
  • Replies 101
Hey All
Details: R33 s1 gts-t 1995 unkown alarm (stock?)
i can't open my drivers side door...
Now i have to climb over the passengers side every time i want to get in... and thats not easy for a 6ft guy...
Any reason why the door won't unlock?
passenger side door locking and unlocking fine no trouble at all,both sides window working fine as well.
"if yes" could anyone please give me some direction or address to some good automotive locksmith.
i tried all tricks but all failed.anyone had this kind of trouble before??
i will be greatly thankful,like always...
Hey All
Can you open the door using the internal door handle or is it totally unable to open using both handles? If you can open it, you can remove the door trim and take a photo and that could possibly help us point you in the right direction
-D
Hey guys thanx for all help and input,Basically i went to the RICK @ AUTO PERFECTION and he removed a trim slightly and nothing broke.
Thanks god for that and rick too,anyways it was something wrong with lock itself somehow Rick able to fixed the problem.
Took him 1 hour and cost me $80.
i am happy with the price and service..
i am very very thnxfull guys for your concern and help,keep it up the good help.
  • 4 months later...
hello all,could anyone please tell me,where to buy new radiator for R33 GTS-T auto.
If possible give me some idea about price as well...??
For original try Nissan would be a bit pricey I would say. Also try your local Radiator Supplier/Mechanic, maybe even Natrad, however most people for the money get an Alloy Radiator - ISC, Autobarn, Ebay, SAU Sponsor, etc.
Watch out some automatic cars have trans coolers built into the radiator bottoms !! No idea which skylines except r31 do
and watch out for sensors and places to put them on radiators , 33 have sensors 34 dont ISC radiator has the spot for one but not sure if its the right size or not
I have a 34 radator but no sensor spot for 33 and its a 5 spd model , ( yes i know some of the auto rb engines use external coolers i use one for powersteering lol)
Man thats confusing :closedeyes: now i am stuck in sensors and in trans coolar so anyone, so kind to give me some direction where to go for radiators...
i dont know much about the cars,as i love skyline but dont know much about them.
Always busy working so dont have much time to learn about the cars.so always depend on your kind helpfull advises
Isc a trader here - ryan should be able to help
Or grab a performance car mag , lots of people sell em , change your coolant ( flush ) and do your hoses at the same time
Thermostat as well
just to save chasing your tail doing it twice !!
belts ?
Is it due for big service timing belt etc just do it in one big hit to save labour time
Its a bit of a dodgy fix but works
You need to drain the radiator down below the leak if its the top tank
Dry the area and wipe all around the alloy plastic joint ( prob were its leaking a common problem )
take the two brackets loose holding the radiator , sometimes the top hose has to come off , tip the radiator a tad so you can do both front and back of the tank
Wipe the whole area of the top tank and alloy tabs with a wet metho rag let it dry It needs to be clean
Take some channel lock pliers and a old towel to protect the teeth tearing into anything
You need to flip the channel lock pliers so there upside down use the rag and your going to gently but firmly squeeze the alloy tabs a little at a time all the way around the radiator top tank, use care once it starts to bend it can go too far and break off or just leak worse , just work it slow and a few times around should be fine
Then take black hi temp rtv on your finger and backfill the area completely around the alloy plastic top tank till the alloy and rtv silicone are about even
You may want gloves rtv can give some people a rash ? , smooth the rtv with a water wet finger and wipe off messy areas , let it sit for a few hours depending on temp till its dry , pop on hose and put the two top brackets back on fill up the radiator burp the top and bottom hoses by squeezing them to get rid of air pockets a bit top up all the way and put cap on , turn the heater on hot and fan on low run the car till its up to temp while watching the radiator for leaks ? It should be fixed now ( my old r31 has been this way for 11 years now still perfect ) use proper coolant and dont mix brands except in emergency it will kill the alloy in less then a year
If it still leaks or leaks somewhere else then a quick fix is from sprint auto parts , go in and
Ask for silver solder radiator sealer , comes in a tube and is silver dust so beware , drain a bit of coolant down if needed add the dust to your radiator slowly , rinse it down with coolant or distilled water , wipe the radiator cap area off and put cap on let it run for about 15 min and it should seal just about any leak in the system including head gaskets , heater cores seeping , its always good to carry in your safety kit for the roadside
Its the only one that works without fail , eggs can as well but thats mess haha
the silver solder can be left in long term if required it doesnt seem to harm anything unless your radiator is completely blocked up
Remember to do this with a cold engine to avoid a bath in boiling coolant in the face or trying to find your cap after it shoots into space lol
good luck its pretty easy to do just watch those alloy tabs they break off easy once they start to bend ( very brittle )
Top up your overflow tank just above full and it will suck in the extra once the engine cools a few times , the heater must be one as well or you will get a air pocket and overheat the head
Never run adelaide tap water in your car unless emergency , coolant or distilled only
The heater should blow hot too if not you have a blockage in the hose or heater core and it needs a flush out at min
  • 4 months later...
Hello all again time to change R33 gts-t auto RADIATOR so please friend help me out..my question is WHAT TO DO AND WHAT NOT TO DO,WHILE CHANGING THE RADIATOR.
What kind of coolant is perfect for skyline's.
i checked some thread but not much help...if someone kind enough and put some advise that will be great..as i wanted to change radiator myself with basic mechanical knowledge..thanx
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
