1, have new radiator handy
2, buy tectaloy xtra cool gold (green colour and concentrate - mix with rain water or distilled) found at sprints or supercheap - this is what I personally use and works a treat other people use different brands etc.
3, make sure you have a drip tray to catch coolant
4, have car on jack stands for easier access or ramps
5, take off radiator cap
6, get underneath car, undo bottom radiator hose, let drain, also make sure your not in its firing line
7, if theres auto trans lines to radiator, clamp them with brake hose clamps
8, remove hoses, minimal auto trans fluid should leak away
9, undo all other hose lines etc
10, remove top brackets + any electrical (if there is)
11, remove radiator - double check to ensure radiator is exact match.
then do the reverse. hope this helps.
ps should also be guidelines on back of coolant bottle for mixing ratios.
*note* tho that you may need to top up automatic trans oil level if there are automatic trans lines connected to radiator.
  • Replies 101
it shouldnt be a problem, if you clamp the hoses. just go to your mechanic and ask him if it needs a topup or not (should still be fine as ive done a few radiators with auto trans lines added to them)
  • 3 months later...
Hello friends i need some help,2011 i changed timing belt and seals on my R33 gts-t.
from last few weeks i got little oil leak in engine arond the crack seal area and i took car to the same mechnic for check and he said its seem like its crank seal leaking.
do you guys think crank seal leaked after 15000 km ?? he asking $300 for repair..is it right amount ?? please help me out..if you know some good mechnic and give me some idea about the price that will be great..right now i am on tight budget..thanx
Crank seals can leak in ten min of installed wrong
or crank floating around
  • 3 weeks later...
Hey guys could you please check this mechnic bill/worksheet and suggest me it is right....
Work Done.
1.Remove all belts,timing covers and timing belt.
2.Remove cam and crank gears. NO LEAK FOUND
3.Clean all removed parts and De-grease engine,with cover off also.
4.Tighten cam cover gasket down and re-check all ok..
IF LEAK CONTINUES -WE MAY NEED TO REPLACE CAM COVER GASKET..
final bill $275...
Now guys tell me what to do,oil leak still there..i asked same time when i went to pick car why you didnt changed cam gasket if its fu888ked...oil leak still there...so do you guys think he going to charge me again...
how much time he need to change CAM COVER GASKET?? PLEASE ADVISE ME AS YOU DID IN PAST.
for labour the bill sounds right, BUT they should have replaced the gasket if there was any doubt about how worn it was.
They didnt, because they want you to pay up, experience the problem again, then come back for more charge$.
Go see Shaun at Boostworx
if its just cam cover gaskets you should give it ago yourself, not a very hard job at all, just takes a while to get to them because of the hoses/piping thats in the way, def save yourself some dosh
My mechenical knowledge not that high to try myself,i booked same guy on monday.he said he will put cam cover gasket,but didnt mentioned about money and i didnt asked either.
but sure i will ask before job done tomorow,hope we will come on some agreement.but this is last visit to this guy next time SHAUN thats for sure..
yeah you are spot about the personal experience,after saw all the way while they were changing cam gasket and half moon
i am 100% sure i can change that myself now...far out man cost me $400 total and gasket cost $109.90 so you are right do it yourself good idea.thanx for help guys hope all go well now..
  • 2 months later...
Well I dont have an R33 BUT!.....I do have a R34 GTT Nizmo. With the nizmo exhaust that opens up and shuts like a varex muffler. So this afternoon I un-siezed the valve and kept it open as the switch doesnt work anymore and I cannot find a thread to help me with the motor or relay for this but anywho....The point I'm making is that after opening the valve I realised how restricted the exhaust was and the quite real difference I felt after opening up the exhaust. So if you are looking for more power, then free flowing and opening up the exhaust should be you're first point of call. As for the fuel economy....you bought a high performance vehicle dude :) Welcome to the cub.
i changed and last week done service including..oil change,transmission service,plugs change,O2 senson change,brake pads change..total cost me $1000.. but no diffrence in fuel economy and power as well...
Far out 1k for a full service, thats pretty steep, dont even know if that inclided clutch, radiator and brake fluids, but next time do it yaself and save ship loads
  • 7 months later...
hey all people am back to you guys again to get some idea's and help, i searched in fourm for my problem but no cure for my car with search engine.
car in question is R33 gts-t s1 auto with catback exuast.rest is stock.
am having a problem with my car,recently i was driving and on a intersection its just died on me so i thought whats wrong and i started again and its start no trouble.
since then its start great every arvo as i work in arvo shifts,nothing drama's for 20 minutes driving and then its just cut itself dosn't matter i am on intersection or driving its just shut it off and then if i start its good again and after few minutes same cuts out again.
during the night when i finished my job and driving home no drama most of time.
i searched in this fourm and i cleaned AFM,air valve,change oil,oil filter,fuel and air filter but nothing good
today again after 20 minutes driving same situation but driving back at night no problem.
i dont know what to think and where to look....if you guys know anything or faced this kind of problem in past please be kind and show me some right way to fix it.
Thanks All In advance
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
