1, have new radiator handy
2, buy tectaloy xtra cool gold (green colour and concentrate - mix with rain water or distilled) found at sprints or supercheap - this is what I personally use and works a treat other people use different brands etc.
3, make sure you have a drip tray to catch coolant
4, have car on jack stands for easier access or ramps
5, take off radiator cap
6, get underneath car, undo bottom radiator hose, let drain, also make sure your not in its firing line
7, if theres auto trans lines to radiator, clamp them with brake hose clamps
8, remove hoses, minimal auto trans fluid should leak away
9, undo all other hose lines etc
10, remove top brackets + any electrical (if there is)
11, remove radiator - double check to ensure radiator is exact match.
then do the reverse. hope this helps.
ps should also be guidelines on back of coolant bottle for mixing ratios.
*note* tho that you may need to top up automatic trans oil level if there are automatic trans lines connected to radiator.
  • Replies 101
it shouldnt be a problem, if you clamp the hoses. just go to your mechanic and ask him if it needs a topup or not (should still be fine as ive done a few radiators with auto trans lines added to them)
  • 3 months later...
Hello friends i need some help,2011 i changed timing belt and seals on my R33 gts-t.
from last few weeks i got little oil leak in engine arond the crack seal area and i took car to the same mechnic for check and he said its seem like its crank seal leaking.
do you guys think crank seal leaked after 15000 km ?? he asking $300 for repair..is it right amount ?? please help me out..if you know some good mechnic and give me some idea about the price that will be great..right now i am on tight budget..thanx
Crank seals can leak in ten min of installed wrong
or crank floating around
  • 3 weeks later...
Hey guys could you please check this mechnic bill/worksheet and suggest me it is right....
Work Done.
1.Remove all belts,timing covers and timing belt.
2.Remove cam and crank gears. NO LEAK FOUND
3.Clean all removed parts and De-grease engine,with cover off also.
4.Tighten cam cover gasket down and re-check all ok..
IF LEAK CONTINUES -WE MAY NEED TO REPLACE CAM COVER GASKET..
final bill $275...
Now guys tell me what to do,oil leak still there..i asked same time when i went to pick car why you didnt changed cam gasket if its fu888ked...oil leak still there...so do you guys think he going to charge me again...
how much time he need to change CAM COVER GASKET?? PLEASE ADVISE ME AS YOU DID IN PAST.
for labour the bill sounds right, BUT they should have replaced the gasket if there was any doubt about how worn it was.
They didnt, because they want you to pay up, experience the problem again, then come back for more charge$.
Go see Shaun at Boostworx
if its just cam cover gaskets you should give it ago yourself, not a very hard job at all, just takes a while to get to them because of the hoses/piping thats in the way, def save yourself some dosh
My mechenical knowledge not that high to try myself,i booked same guy on monday.he said he will put cam cover gasket,but didnt mentioned about money and i didnt asked either.
but sure i will ask before job done tomorow,hope we will come on some agreement.but this is last visit to this guy next time SHAUN thats for sure..
yeah you are spot about the personal experience,after saw all the way while they were changing cam gasket and half moon
i am 100% sure i can change that myself now...far out man cost me $400 total and gasket cost $109.90 so you are right do it yourself good idea.thanx for help guys hope all go well now..
  • 2 months later...
Well I dont have an R33 BUT!.....I do have a R34 GTT Nizmo. With the nizmo exhaust that opens up and shuts like a varex muffler. So this afternoon I un-siezed the valve and kept it open as the switch doesnt work anymore and I cannot find a thread to help me with the motor or relay for this but anywho....The point I'm making is that after opening the valve I realised how restricted the exhaust was and the quite real difference I felt after opening up the exhaust. So if you are looking for more power, then free flowing and opening up the exhaust should be you're first point of call. As for the fuel economy....you bought a high performance vehicle dude :) Welcome to the cub.
i changed and last week done service including..oil change,transmission service,plugs change,O2 senson change,brake pads change..total cost me $1000.. but no diffrence in fuel economy and power as well...
Far out 1k for a full service, thats pretty steep, dont even know if that inclided clutch, radiator and brake fluids, but next time do it yaself and save ship loads
  • 7 months later...
hey all people am back to you guys again to get some idea's and help, i searched in fourm for my problem but no cure for my car with search engine.
car in question is R33 gts-t s1 auto with catback exuast.rest is stock.
am having a problem with my car,recently i was driving and on a intersection its just died on me so i thought whats wrong and i started again and its start no trouble.
since then its start great every arvo as i work in arvo shifts,nothing drama's for 20 minutes driving and then its just cut itself dosn't matter i am on intersection or driving its just shut it off and then if i start its good again and after few minutes same cuts out again.
during the night when i finished my job and driving home no drama most of time.
i searched in this fourm and i cleaned AFM,air valve,change oil,oil filter,fuel and air filter but nothing good
today again after 20 minutes driving same situation but driving back at night no problem.
i dont know what to think and where to look....if you guys know anything or faced this kind of problem in past please be kind and show me some right way to fix it.
Thanks All In advance
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
