R34gtt Hi Flow Turbo Kit
hey u still considering my offer of 800 delivered for the turbo me in tonwsville
Hey buddy, had a better offer with local pick up. I didn't hear back from you, so i thought you were still considering. Sorry mate.
Hey Guys,
Still have -
Custom Airbox
Split Dump pipe - $100
Power FC - $1200
Z32 AFM & Plug - Currently on EBAY (Starting at $250.00)
SARD 550cc Injectors - Coming out of the car end of Nov $700.00
Turbotech Boost controller - $15
17 inch wheels (8inch front 9 inch rear) with NEW tyres for $400.00
There will be other parts including stereo gear and standard bits available soon.
Cheers
Matt
Price and photos of air box wheels please. Also more specs of wheels and tyres?
Wheels are Starcorp Racing Tracer II's and were only used for rolling my car around while i had my works rims repaired, pretty ugly imo...
Airbox i will get pics of, i was meant to do that for someone else ages ago but haven't got around to it :(
Hey Guys,
Still have -
Custom Airbox
Power FC - $1200
Cheers
Matt
Still for sale guys, will start removing parts from the car soon :(
Z32AFM & PLUG NOW SOLD
I also found me set of brand new Nolathane rear lower control arm bushes, for some reason my GTT needed the R33 ones so i have this set of R34 GTT ones available for $50.00 + Postage (Cost me near $80.00 from memory)
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
