Hey Guys,
Had a peek underneath the car and the SMIC is sitting about 20-30mm lower than it should be. Basically the lowest level of the SMIC is about 20-30mm below the lowest level of the front bar.
I've been told that there may be a couple of screws that have fallen off and so will need to get under the car and check it out.
I haven't hit anything hard or fast, so I'm really not sure how it's dropped to that point.
Any others experienced the same thing?
Reckon Japspec cable ties will do the job to patch it up?
If anyone has an R33 S2 with stock SMIC and stock front bar, if they could take a picture of it and the undertray and post it up here that would be appreciated too. I'm not really sure what it 'should' look like.
Cheers!
Edited by enndee
https://www.sau.com.au/forums/topic/334403-stock-r33-s2-smic-mounting-issue/
That sounds a bit odd, because for it to drop it would have to be dropping out of the intercooler pipes too.
Are you sure it doesnt have an R34 sidemount? They sit a little lower than the R33, and could stick past the undertray slightly. I know when i did mine (before mt FMIC) it popped all the screws for the undertray because it was too tall, and there was alot of pressure on them.
Sorry it doesnt have the front on. But you can see how much lower it is. I just cant see it having dropped as the piping inside the engine bay would be holding onto it.
Edited by gotRICE?
Thanks for the pics and prompt reply man, that really has helped! - I'll take some pics of mine if I can get home before the sun goes down. I can see what you mean by it being taller, it definitely juts out more.
I've only had this car for about 2-3 months, and I can't really remember it jutting out like how it is now. I am the second owner of this car in Australia.
I'd be surprised if it was a 34 SMIC on a number of levels, firstly, I was told by the previous owner that the car is completely stock apart from a K&N airbox, and secondly, I was actually thinking of doing the 34 SMIC upgrade!
Obviously, I can't be 100% sure that it isn't a 34 cooler, I mean how could anyone really tell unless they've inspected it uber thoroughly...
I'll posty posty some pics soon :)
Cheers!
No problem dude! Theres no way the stock one could stick below the bar unless something was really odd!
You'l know pretty quick. Heres a top view. The size difference is huge.
Good luck! Post up them pics when you get them!
Cheers gotRice!
Thanks for the comparison pics too mate, managed to get some photos although it was done at night so they're a little underexposed, and also a weird blue colour. I should really learn more about our DSLR, anyway the pics, sorry if their a bit shit :D:
I really don't have enough experience to tell, but do you think that's the R34 SMIC?
If not, how can I diagnose what the issue is, everything seems normal and boost comes on fine, although I'm pretty sure the intercooler has dropped a little bit more... :)
Yeah id say for a fact thats an R34 side mount.
From what you can see it looks as if its about 17 rows. Give or take from what you cant see.
The amount its bulging out the bottom was similar to mine, and as i said it was putting so much pressure on the undertray that all the bolts/screws pooped out and the front wheel ate the rest of it in a smokey heap :D
Pull the bottom off and throw a tape measure over the thickness of it. Im pretty sure they are about 70-75mm thick.
Edited by gotRICE?
Thanks for all your help mate! :D
Looks like I've got a free upgrade with the burger... :)
Lol, now I'm beginning to wonder what type of life this car has had over in Japland, and even here... Or maybe I really don't want to know... :(
I guess I just have to drive more carefully over bumps then, I can already notice a few chinks getting taken out of the bottom of the IC.
Cheers for all your help!
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 馃槕. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
