LOL no one talks cm in threads...
I'd say it is M10 x 1.25 so he needs to drill the hole 8.5mm diameter
EDIT: My bad, should be an 8.8mm drill
Edited by .:: GimpS-R34 ::.
what craig said above is right. but he also should've pointed out that the 1.25 bit of it is what the thread spacing is. in this case it means the thread is spaced at 1.25mm apart. you will need to know this when your mate taps the thread into it.
