  • Replies 60
Posted Images
Many of my mates have worse records than that. Drink driving, speeding, loss of license, blah blah blah. Some of them are only 21/22. Nothing out of the ordinary these days with everything going on.
do they have there licenses now??? Second loss of license is ment to be a 3 year suspension... I got away on a technicality.
Have you learnt your lesson?
Yes Ive Learnt my lesson...
Getting parts from Nissan as new is just cruel :) He is paying for them, I have a lot of respect for him for that knowing the stories I have been told of people just not coughing up or waiting months and months for repayment. Besides, the bumper and bonnet were already aftermarket. It does help our best mate is a panel beater. He will do the spray for the cost of the paint.
ouch that looks almost as bad as mine...:)....good to hear that you have learnt your lesson mate....but drifting or trying to drift on public roads is just asking for trouble mate.....take it to the track and then drift or else drive it like a granny on the roads and be safe.....these things are fun to drive and have but they can also become a weapon within seconds :D
ouch that looks almost as bad as mine... :D ....good to hear that you have learnt your lesson mate....but drifting or trying to drift on public roads is just asking for trouble mate.....take it to the track and then drift or else drive it like a granny on the roads and be safe.....these things are fun to drive and have but they can also become a weapon within seconds :(
Just like to add that I wasn't driving :) Just to refresh your memory. Even he was driving sensibly but we were out at Mt Craford and it was wet. Think he just under estimated the power.
Anyone else coming down to help fix it on Saturday? I know Steve will be there. Along with the bloke who crashed it.
Yes.
One mate lost his license (P1's), continued to drive around, got caught 5 times at random times, got suspended for another year, still drove around and now he's back on his P1's until he's 25 (just turned 23).
On top of that, he's been done for speeding, running red lights, talking on the phone, running from a bretho, changing drivers in front of a bretho, driving unlicensed and driving an unregistered car.
Makes me angry how he got away with all of this and still gets to drive... Even driving while under suspension. Yet I get done in the back seat of a car with no seatbelt on and get hit with 3 points (even though I wasn't driving).
We all learn our lesson eventually.
Yes.
Not wearing a seatbelt! How hard is it! :) More importantly, tell your mate to get some better tint! If a cop noticed you didnt have a seatbelt on, He really must have some clean glass.
I hate getting done for stupid stuff
    • Updating results following our SR20det project. Data collected form improves future turbocharger making and high flowing services. So far differences between G and GT series turbine wheels, we are in the process of making a new turbine, the aim is for better mid top range flow without gain too much lag.  Result is back to back comparison of G25-660 and GTX2867 spec turbochargers on the same car, nothing changed apart from turbocharger. Both tuned to knock limit from pump 98 fuel (US Ron93). GTX2867 was about 400RPM more responsive making 255rwkws while G25-660 made 17 extra Kws with wider spread of torque after 4500RPM finishing off at 272rwkws.
    • @GTSBoy i tried to jumper the wires and got the steering wheel light to come on which is right under the gear indication but that still doesnt come on.  Can it be an issue with my cluster?
    • Given that you have seen the dash indicator work briefly, then it would seem like you have a simple wiring problem. What happens when you simply jumper the wires on the "steering wheel switch"?
    • Yesterday's day in review: All the wiring to the lights up the front how I want it, is ran, terminated, and all to length. The only lighting up front I haven't finished is the side indicators, as I need to get to the partly cutup factory loom, and find the plugs for them. Interesting note, the side indicators use the exact same plug that's in the doors for something else that I don't remember what it is... So that plug better be careful...   Power steering solenoid, on the R33 is variable, and from memory PWM. The Ford's control from the docs I have so far, is it's just a on or off control. So I'm not sure it's what I want, and in any case, power steering running, but at its heaviest (solenoid off) is likely what I'll want anyway, so I'm not yet touching it at all. All the wiring I can complete so far, is done. There are 3 wires I need to make a plug for at the ECU, and these are just for the vehicle speed sensor, of which I need to get a T5 from an AU, so I can use its output that has the speed sensor on it. (My car doesn't have ABS, otherwise I'd set it up to use one of the ring gears on that). I need to buy new headlight globes and front parker globes, otherwise I could show photos of lights working. Current fuel lines in and out on this motor are "5/16". I'll order hardline, and some AN fittings for that, and I just need to 100% check fuel line size at the tank end, to get the ends for it. I'm also looking at a few options for the banjo bolts to AN fittings for the power steering rack. I'll pull the reservoir off the Barras PS pump. There's an off the shelf fitting for that pump for a -10 AN feed, and it'll use a 16mm to dash -6 an outlet to feed the rack. I'll be making my own power steering reservoir, I'm going through the thought process at the moment of how I'll run the baffles, and I need to research another idea for it too.
    • Two inlet runners changes the engines characteristics requiring less fuel to make torque at different points in the rev range. The smaller diameter inlet runners on the DET increases air flow speed, which improves atomisation of fuel, particularly in low load/idle for better burn, and in specific areas of the engine, (areas you would use when driving normally) increases the efficiency. All of those items change how efficient the engine is at different speeds. The changes on the neo help slightly to improve emissions where it matters. The overall improvements won't be the likes of going from an engine built in the 70s to an engine built in the 2000s, it's just a small step. But still leaves it the RB with the best chance of improvement.   As for your comment about the whole using a cat to not need to worry about those gases. Two things, no system is 100% perfect. It won't eliminate everything. So reduce the quantity you put into it, you still reduce the output. Two, make that system do less work, and it's likely to survive a little bit longer. Funnily enough to, one trick employed to get cats up to temp, AND to drastically reduce emissions before they get up to temp, is to reduce ignition timing.
