$1,000.00 dollars cash has been put up by Powercruise for the fastest lap at the Jap Nats 26th Sept.
Competition is limited to 100 cars with the fastest 20 sprinters from the morning being invitied to take part in a 1 Lap Dash to win $1,000 in cash.
Entry forms are available from: http://www.queenslandraceway.com.au/pdf/e_...atEntryForm.pdf
Get your entry in now as only 100 entries will be taken
https://www.sau.com.au/forums/topic/334444-jap-nats-at-lakeside-26th-sept/
Oh don't worry! I'm hatching a plan!
What, are you going to borrow the Option 1 S14 :starwars:
If a certain person was not involved in this event I would have entered but a 60 will not be good enough to win so meh.........
Edited by 260DET
Exactly, should be a great day! I haven't seen an entry list.
Berry's gonna bring the 32 so that'll be fantastic.
No doubt there'll be plenty of stuff to ogle at in the car show too.
I gotta get someone to drive to 34 out to display.
Get on board Ben.
http://www.sauqld.com/ipb/index.php?showtopic=2866
I'm out.
There was 1 thing that I was not happy with when i was building the enigine, the rings just didn't quite sit right. They were a set by JE as ACL couldn't supply any rings for them. I have done 10,000 km on the new motor running 12-14 psi and have pulled it down as part of a diagnostic process. I wanted to see how the rings were doing in particular.
The bearings, bore, buckets, cams etc are perfect, the rings though, "Not, Happy, Jan! uneven ware.
I have done some homework over the last month, ACL changed the ring specs part way through the production run. So, there are 2 different ring sets for 1 pistion part number. You can't buy a ring set for the earlier spec pistions, I have the early spec pistions. I'm pretty sure they were made by ROSS in the US for ACL. Ross can supply a set of rings for us, will just take a while.
Unfortunately I won't be compeeting, but I will be watching and snapping shots.
bugger :) will you have it together for the QLD Champs at Morgan Park?
I'm looking forward to both these events. Diff's coming out tomorrow - tired of the open wheeling viscous diff so I'm planning to weld it up. Would love to get hold of a wing too, but I think I've left it a bit late.
ended up shimming the V-LSD instead. Mainly so that its still nice to drive on the road. Hopefully it works OK on the track for a while too. Should be a few tenths in that if it eliminates some wheelspin. Cost next to nothing thanks to Paul at Option 1 Garage, so I figured its worth a try. Plus it maintains my 'full street trim' excuse >_<
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
