After searching for the last 2 hours reading through old threads ive given up!
Im thinking about making up a oil cooler and relocation kit from earls as they dont seem to sell them in kits?
Has anyone done this and know exactly what they used and how much it ended up costing?
I might just have to stop being lazy and measure everything up but would be good to know exactly what other people of done i want the biggest cooler i can fit in a 32 gtrs duct (dont want one between cooler and radiator)
cheers!
https://www.sau.com.au/forums/topic/334457-earls-oil-cooler-questions/
I run a setup of all Earl/Speedflow bits, Earl's & Speedflow -10 fittings, Earl's -10 steel braided lines, Earl's 19row core, Earl's relocator in my R32 GTR, boostworx installed in the passenger duct and they said they barely made it fit.
Do you know how much all those bits cost? just wondering if its easier to go a jap brand kit
Some of the high end jap cooler kits are actually just all Earl's bits and pieces (from what I understand, and are actually better than the jap stuff) that are made to the correct lengths and fittings required for that specific model of skyline and mounting location, mine was a Trust kit meant for a R33/R34 GTR to be mounted behind the intercooler.
I needed extra Speedflow fittings because I added a B&M in-line oil thermostat, plus needed extra -10 hose to run it all the way to the passenger side duct.
The most expensive part by far is the fittings.
Made a mistake too, it was a 16row not a 19row core
honestly it will be easier to just get the trust R32 GTR duct mounted kit. it goes in the passenger side duct (no room in drivers side with factory BOVs), it includes the right lenths of earls -10 hose (all pre-cut and assemlbed), it has all the right earls fittings, it comes with brackets to mount the core, it comes with a good quality engine take off plate (complete with sender ports), it comes with remote filter mount which has a built in thermostat and more pressure and temp sender ports and the brackets to mount it neatly too. plus they have a very good quality core (not earls). only the fittings and lines are earls, everything else is trust specific (core, take off, filter mount, etc).
yes they cost money. around $1000 but you get a lot for that money and they are a snack to fit compared to having to measure and cut lines yourself. plus it doesn't take many -10 earls fittings to work up a few hundred bucks just in those (kit has 8 fittings in it average about $40 each).
cheers!
I used a serck speed core in the driver's side (deleted BOVs). $300 or so.
Thermostat + filter mount where battery used to be. $50 or so.
Pirtek braided lines x 4 (2 block <> filter; 2 filter <> cooler) ended up using 4-5m of hose and 8 fittings. Allow another $300 or so.
Figure out where you're going to put the core, drop in to your local Pirtek and ask. They will make the hoses to fit and charge you for what you use.
Cheers,
SW
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
