Whether Exhaust For 2doors R34 Gtt Can Be Fit In A 4doors One Straight Away ?
hey guys,
someone is selling me a exhaust which came off his 2 doors r34 gtt.
im going to fit it in my r34 seden.
but we are not sure if the exhaust for a 2doors r34 can be fit in a 4doors one straight away?
or have to do some modification?
cheers,
ryan
It's not a direct fit and will need modification. Have a look at these threads, there's some pics too:
- Exhaust System Lengths On R34 Gtt Sedan?, Modifying R34 GTT Coupe or R33 GTSt system to suit?
- Installing Jjr Bellmouth Front/dump Pipe On R34, Who's done it, any advice or tips?
It's certainly doable but what exactly is required depends on the exhaust. The pipe lenghts are slightly different as well as the mid muffler location (I think). You'll probably also find that aftermarket systems don't necessarily follow the same 'path' as the stock exhaust so that'll affect things too.
I reckon a second hand system is ok to modify but I certainly wouldn't buy a brand new exhaust that'd need to be hacked up straight away to fit :)
thanks guys
i thought they are just a bit different in the length.. but unfortunately they are 15-20cm different....
let's say if a 4doors turbo back exhaust want to fit in a 2doors one, maybe we can just cut a bit off somewhere from the cat-back.
but im going to fit a 2doors one into my seden.. so basically im going to make the short one longer.. how can it be done? ...
thanks guys
you just answered your own question bro,
4door exhaust fitting onto 2door = cutting abit off.
2door exhaust fitting onto 4door = cut and weld a little bit more on. exhaust shop should be able to do all this for you
should be a piece of piss
so that's it?
cheers mate!
yeah pretty much, cut where flange is, get the right length piping to cat, weld on flange back on and new piping, done. vrooom vrooom
Edited by viet_boi
    • Jamie does know his stuff , you might just want to give them a call and ask - here is their FB page  -  https://www.facebook.com/profile.php/?id=100063506985512 - you will find the number to call them on.
    • Do you think the guys in Penrith are install the E85 Kit?
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
