S1 And S2 4wd Autos
I'm guessing you mean something like this size? https://www.supercheapauto.com.au/p/bodyworx-bodyworx-hard-soft-sanding-block---70-x-135mm/594184.html?cgid=SCA01100303#srsltid=AfmBOoq_qZTEe3boann9BaHiB2f59dxJlosWLzCr0zm_weHgUlDX-N5f&start=6 Are they sanded completely flat? -
Just a standard sanding block size. With the rock chipa they are quite small. I sanded them as you could feel the edges.
Say you've just laid all your filler and your about to start sanding, how large is the sanding block your using? Like a high fill primer? Technically possible but would be a nightmare. Just guessing from the photo, but they look small enough that you might get away with using a 1k spot putty. Normally you'd use something like this on pinholes but with the type of project you're working on I'd give it a go.
