Custom Glass Carbon Fibre R33 Projector Headlights Group Buy!
Been wondering when anyone's going to ever make aftermarket headlights for 33s lol. I'm in on this for sure.
Agreed with the 1 projector per headlight idea too, keeps the cost down and halogen is more practical with the existing high beam set-up on r33s (low beams turns off when high beams are activated).
will it be a problem flashing your headlights as when you flash the hi-beams the low be does turn off yeah?
is that bad for the lights being projector hid?
its illegal right to have the low beam stay on while the hi-beam is on, yes?
This group buy idea is making me hold fof on all other purchases for the 33 now you realise, until I know how much of my monthly mod budget will be taken up by this one...
Should we be looking at headlight protectors as well now?
since they would be glass, Id be worried about stones hitting my nice new glass lenses...
Personally I wouldn't worry about it to much, glass is pretty strong.
I'm in too, depending on price.
So will this be a changeover kinda deal with my stock headlights? coz the brackets and housing on my stockies are shagged that's why I'm interested in these.
Yeah we will have to send our headlights to them and they do the modifications and send them back. I'm in the same situation man, my drivers side headlight is screwed so will have to buy one to replace it prior to doing this.
I sent the guys an email with a link to this thread so they can read through every ones suggestions. I also sent some pics of S3 GTR headlights to work off as a basis.
I am only new to this forum as i just bought a R33 GTS-T S2 on the weekend.
Heres hoping that I can join in on this group-buy?
i have already started looking online for some replacements!
Interested in asking if they can make just the front plastic of the R34 headlights outta glass.. Would be interested in that depending price..
Wow... PM-R33, you are the man.
Not sure how many people I speak for but being an owner of a 1995 R33 GTR I have yellow headlights and I would be super happy if there was a direct replacement of the OEM plastic lens with a replacement glass lens!
UPDATE
Bit of news from Rich:
I assure you the final product will not be “try hard” Honda boy look. We have been asked to do Audi and BMW LED’s on the Supra lights but simply refuse too. We won’t manufacture something that we are not proud of. We are all about quality and attention to detail. All product is manufactured here in Australia. We don’t use any tacky e-bay techniques. The glass is cut and curved 1 lens at a time. The carbon fibre is made via vacuum infusion with high temp resins and UV protected gel coat. When we sell carbon fibre, we DON’T use fibreglass to make a more cost effective product, we make it properly. We even go to the trouble of importing our resin systems from France.
These are the Hella projectors that will be used:
As for the kits, there will be two options to choose from.
Kit 1: Carbon fibre bezel, Glass lens, HELLA Projector low beam, re-designed Parker lights, HELLA adjuster.
Kit 2: Carbon fibre bezel, Glass lens, HELLA Projector low beam, re-designed Parker lights, 6000k hid bulbs, HELLA ballasts, HELLA relay, HELLA adjuster.
The LED parker/indicator design is going to be the tricky part to create something unique that look aggressive. If any one has any designs/photoshops that they think will look good chuck them up.
Here's something that I quickly did up in Paint.
Edited by PM-R33
  • Like 1
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
